want to go lst... need help..
hi i have a stock da with a almost a 200,000 mileage b18a1... i want to go lst for it but want to kno where can i buy a good but cheap turbo setup for it.. and do u kno how much will i gain with a stock motor... does anyone kno of a page and can read and learn more about this setup...
first:
good reliable cheap.
you only get 2.
second, actually before you even get that far (number 1)
do a compression andleak down test and see if it is even worth doing that to that engine.
i am going out on a limb and saying this is your daily?
you only get 2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwuknoit »</TD></TR><TR><TD CLASS="quote">yea it is... do you kno where i can get the test done at?</TD></TR></TABLE>
Your best bet would be to check on a local automotive forum to see if someone will help you out with the compression and leak down test for a 12 pack of beer or something. If not, most shops should have the equipment as well. Both tools are a good thing to own too, especially when messing around with boost on 15+ year old cars.
i think you should use the red search feature....that will help you out a lot.
the tools are= cylinder compression tester, cylinder leak down tester......as described earlier.
boost on a 200k original, non rebuilt engine.....are you serious?
do you know what your getting yourself into?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwuknoit »</TD></TR><TR><TD CLASS="quote">does anyone know what tool they use to do the test and where can I get it at....</TD></TR></TABLE>
Compression testers:
http://www.jegs.com/webapp/wcs...ester
Leak down testers:
http://www.jegs.com/webapp/wcs...+down
You should be able to find both of these at a local automotive parts store or Sears.
Leak down testers:
gmacarize
Jul 28, 2006 08:39 AM
GokuSs4
Apr 26, 2004 12:47 PM
