No Spark
Old May 15, 2008 | 12:22 PM
hondaluver12's Avatar
Default No Spark
Im not getting any spark from my 1.6 non-vtec(ZC) engine w/DPFI. I just replaced my control module and still no spark. Im just wanting to get a new distributor for it. So what distributor should i get?one for a 1.6 or one for a 1.5? I have a pm9 ecu. If can please help...
Old May 15, 2008 | 12:26 PM
zccr-xsi's Avatar
HAVE U CHECK TTHE COIL and or ignitor?maybe the dizzy is no good?
Old May 16, 2008 | 09:59 AM
Default Re: (zccr-xsi)
I have checked the coil and it test out(.8 ohms). I have been told to check the ignitor but when i goto the parts store they look at me like im stupid when i ask i need one....and whats the dizzy?
Old May 16, 2008 | 12:03 PM
kacivic's Avatar
Default Re: (hondaluver12)
dizzy=distributor
if you're using a zc, i seem to remember that it's really similar to the d16, but (if it's the dohc zc) i'd think the head would be different, so i don't know what to tell you about potential compatibility.
Old May 16, 2008 | 03:21 PM
Targa250R's Avatar
be professional
Default Re: No Spark (hondaluver12)
No spark = typically bad coil or ignitor. Coils fail moreso than ignitors on Civics.
I don't know what you mean by "control module." Are you referring to the ECU? Or the ignition control module/ICM (ignitor)?
Check all grounds as well. Are the cap, rotor, and wires in good condition?
PM9 is the STD ECU, so you have a DPFI 1.5L.
Old May 16, 2008 | 06:00 PM
Default Re: No Spark (Targa250R)
I just replaced the ICM, it was $100. And ya the Cap, rotor, wires are in good shape. But when i bought the car someone had already swapped engines( to the SOHC ZC engine) But it still has the DPFI on it that came stock with the car. And it still has the stock PM9 ecu in it. But i tested the coil and it read .8 ohms, and i looked it up and thats where it saposta be.
thewiione
Nov 21, 2013 04:13 PM
88 honda prelude
Jul 28, 2007 05:50 AM
hondaboy90
24
Oct 29, 2006 06:38 PM
CptCorN
Jan 17, 2005 06:33 AM
90CRX
Aug 26, 2003 05:06 PM
