NEW 3 year Project Integra 1st Gen
picke dup an gen1 teg, has 212k on the body, but SUPER CLEAN.....i cant tell what type of motor it has, def of the LS family but on the motor stamp all it says is "ZC" it doesnt say b18a or anything like that .......its weird....to mee it looks exactly like an OBD1 B18a becase the valve cover looks NOT like the smooth top , this one has little raised squarsgoing along the vavle train section of the head cover....anyways pics to come,
3rd gen back up and running, had to swap tranni for a used one temporarily, then going to purchase a diff one later, need todrive..
ridin dirty, no licence , no regestration, no insurance, the only way to go in cali...HA
i need some opinions on 1st gen suspension and exhaust, any help would be great ty. PICS COMING TONIGHT!!!!
ZC (similar to D15Z4, D16Z6, D16A1, D16A3, D16A6, D16A8, D16A9 and D16Z5 engines)
A few D-series variants are labelled "ZC" (usually JDM), but they are not truly a different series.
There are both SOHC and DOHC ZC engines.
The non-VTEC SOHC ZC is similar to the D15Z4 and D16A6 engine, but with more aggressive cam timing.
The VTEC SOHC ZC is identical to the D16Z6, and the DOHC ZC is similar to the D16A1, D16A3, D16A8, D16A9 and D16Z5 engines.
Euro Mk1 (85-87) 1.6 CRX's are fitted with an engine designated "ZC1" which is a higher spec 130 bhp version of the D16a1.
The JDM Browntop ZC from the 84-87 Civic CR-X and Integra made 135hp from the factory.
do you know how the cylinder walls hold up for turbo applications? is it the same block as a b18B/a but the walls are thicker? or is this completly different application, it is DOHC, very strong motor 3rd clutch in this car, 3rd gear seems a little outta place.....but nothing to be worried about ..... this is a NON vtec DOHC motor ZC
well, a friend of mine up here was running a 50 shot on his D16A1 which is practically a ZC. it help up fine.
As for turbo, another few folks up here with JDM CRX SI's had a couple turbo ZC's. They seemed to smoke a bit due to the rings.
Depends on really how much boost you want. IMO a b18b1 is a better platform to boost if you want to keep it non vtec.
djphonics
Apr 18, 2006 07:28 AM
Ahknodd
May 1, 2003 07:47 AM
