02 Accord Coupe V-6 Towing Capacity
I have aquired a small Pop Up Camper 1650 lbs. I live in Tampa and will be towing with the Accord only in Florida. 200-300 miles at the most. I have seen through other threads obtaining a transmission and power steering coolers are a must, and I should be ok. Anyone care to comment?
towing capacity is 1000lbs
towing something that is half the weight of the car is NOT a good idea and a trans cooler is a MUST with those transmissions. Also do not use D4
Yes, that is kind of heavy for the Accord. Check out this tread for more info on towing though.
https://honda-tech.com/zerothread?id=1977607
Spectrum_16
Apr 29, 2008 09:23 PM
