Civic A/C
Old May 15, 2008 | 10:33 AM
black cx's Avatar
Default Civic A/C
I was wondering....On my 2000 civic, the A/C blew cold. The last time i used it was probably 6 months ago. However, yesterday i used the A/C and it wasnt cold....do i need a new compressor or soemthing?
Old May 15, 2008 | 10:46 AM
1CaMw0nDeR's Avatar
Default Re: Civic A/C (black cx)
lol, nothing like being point specific...
so does it blow cold, just not as cold as it used to..??? not blow cold at all..?? blows cold but only for a lil bit than goes away..??? blows cold til u sit at an idle and than doesnt blow cold...???
from what u just said, it could just need a lil vacuum job an recharge possibly...
Old May 15, 2008 | 05:20 PM
black cx's Avatar
doesnt blow cold anymore...its like warmish
Old May 15, 2008 | 05:27 PM
Jonathan_ED3's Avatar
You should run your a/c at least once a week so the o-rings and gaskets don't dry out.
Even if you have it turned to "heat" you can still have the compressor engaged.
You probably lost some freon - good thing it's R134 ...nice and cheap.
Old May 15, 2008 | 05:46 PM
black cx's Avatar
what do i need to replace?
Old May 15, 2008 | 06:04 PM
Well...if you ever have a leak, something is wrong and needs to be replaced (most of the time o-rings or compressor seals)
But you can probably just do with a freon recharge.
Old May 15, 2008 | 08:59 PM
hybridtuner26's Avatar
Default Re: (Jonathan_ED3)
The recharge is cheap from autozone , charge it and see if it leaks and go from there
Old May 15, 2008 | 09:11 PM
hard_boiled_EG's Avatar
Default Re: (hybridtuner26)
when i first bought my car the ac worked great...3 days later it wouldn't get cold anymore....well it wouldn't get cold for 5min the get warm...on and off whenever it wanted to...kinda figure it was the relay by the condensor...don't know if that helped but...good luck
Old May 15, 2008 | 09:30 PM
portaman03's Avatar
May sure you guys have both buttons pushed, the A/C and the recirculation button..
alloysr16s
Honda Civic (2006 - 2015)
28
Jun 24, 2016 01:50 PM
prodjay10
10
May 22, 2016 09:43 PM
texcon
May 29, 2012 09:14 AM
skate1968
Jun 27, 2007 03:58 PM
EX-T
Aug 18, 2003 08:01 PM
