Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
OMNI-POWER K-SERIES 4 BAR MAP SENSOR IN STOCK!!!!!
Old May 15, 2008 | 09:20 AM
ImportAutoPerformance.com's Avatar
Default OMNI-POWER K-SERIES 4 BAR MAP SENSOR IN STOCK!!!!!
***UPDATE: K-SERIES AND B-SERIES MAP SENSOR READY TO SHIP NOW!!!!***
Hello HT Members,
The much anticipated OMNI 4 BAR MAP sensor for the K-series motor is in stock now!
Omnipower 4 bar MAP sensors offer true plug and play with a stealth OEM look. Each sensor can read upto 43+ PSI (3 bar above atmosphere) and are made in the USA. Installation takes less than 1 minute for a clean look with no wiring and mounting headaches. Compatible with all ECU tuning software Including: Hondata, AEM, Motec, and all Freeware.
Key Features:
[*]-40 to 260 degrees Fahrenheit optimal temperature operating range[*]Able to respond from 10% of the pressure scale to 90% of the pressure scale in .001 seconds (the fastest response time of any MAP sensor on the market) which translates into improved boost response.[*]Automatic temperature compensation.[*]True linear scaling for perfect drivability at all boost and vacuum levels.[*]Compatible with all aftermarket engine management systems.[*]Minimum of 99% accurate over full scale range under all conditions including temperature, altitude, and humidity changes.[*]Allows smoother engine operation, higher boost levels, and better drivability than competitor's turbo MAP sensors.[*]Direct plug and play for an easy install and an OEM look. Dimensionally identical to the stock MAP sensor.[*]Each sensor is hand assembled, pressure, and function checked in the USA for unparalleled quality control prior to shipping.
This will fit the following vehicles:
[*]02-06 Acura RSX Type-S[*]02-06 Acura RSX Base[*]02-05 Honda Civic EP3[*]05+ Honda S2000[*]01-05 Honda Civic (all models)
Click Here to Purchase Your K-Series 4 Bar Sensor Now!!
Please contact us if you have any questions!
Modified by ImportAutoPerformance.com at 1:29 PM 7/17/2008
Old Jun 13, 2008 | 11:34 AM
Default Re: OMNI-POWER K-SERIES 4 BAR MAP SENSOR IN STOCK!!!!! (ImportAutoPerformance.com)
Thank GOD we are not underwater:
http://www.msnbc.msn.com/
Orders shipped and PM's replied!
Old Jun 18, 2008 | 11:41 AM
GET YOURS NOW!
PM'S REPLIED
Old Jun 20, 2008 | 01:11 PM
PM's replied and Orders shipped!
Old Jun 25, 2008 | 12:24 PM
Orders....
have.....
shipped!
Old Jun 27, 2008 | 01:33 PM
SHIPPED AND REPLIED! OUT FOR THE WEEKEND!
Old Jul 2, 2008 | 11:12 AM
ALL PM'S REPLIED. THANKS FOR THE ORDERS GUYS!
Old Jul 7, 2008 | 12:54 PM
Orders are out the door!
Old Jul 9, 2008 | 12:19 PM
PM's replied.
Old Jul 11, 2008 | 02:00 PM
ORDERS SHIPPED AND THE WEEKEND IS HERE!
Old Jul 11, 2008 | 09:40 PM
omniman's Avatar
Pictures are your friend.
Omnipower also offers a universal 4 bar MAP sensor for people that use aftermarket throttle bodies that dont accept the stock sensors.
Old Jul 17, 2008 | 12:14 PM
Default Re: OMNI-POWER K-SERIES 4 BAR MAP SENSOR IN STOCK!!!!! (omniman)
BOTH ITEMS IN STOCK NOW!!!!!
ANOTHER INNOVATIVE PRODUCT FROM OMNI-POWER.
Old Jul 22, 2008 | 12:57 PM
PM's replied.
Old Jul 23, 2008 | 12:08 PM
Old Jul 28, 2008 | 12:59 PM
Orders are on the way! Thanks guys.
Old Jul 30, 2008 | 12:24 PM
IAP is here for you! Fellow Honda Lovers
Old Aug 4, 2008 | 12:11 PM
Orders shipped and PM's replied.........................Done
Old Aug 8, 2008 | 12:04 PM
Thanks for all of the orders guys!
Old Aug 12, 2008 | 09:20 AM
PM's replied.
Old Aug 14, 2008 | 10:30 AM
Thanks for the orders! You guys are fantastic.
Old Aug 19, 2008 | 01:51 PM
PM's replied.
Old Aug 22, 2008 | 12:40 PM
Orders shipped, PM's replied, You guys are the best!
Old Aug 28, 2008 | 05:46 PM
Orders shipped and the end of the week is upon us!
Old Sep 3, 2008 | 02:57 PM
PM's replied!
Old Sep 5, 2008 | 01:32 PM
Orders shipped, PM's replied. Now its time for the weekend!
