Minty 1990 B18A1 and Trans, CHEAP
Old May 15, 2008 | 06:22 AM
Dasfinc's Avatar
Default Minty 1990 B18A1 and Trans, CHEAP
I have forsale a Running 1990 B18A1 and cable transmission, Perfect for swapping into 88-91 Civics/CRX's, does not come with clutch/pp (If the flywheel is desired I can ship it at a later date, or I will have it on Sat). To install this into a Civic/CRX you would need Mount kit *Ebay for $75*, and a small alteration to your shift linkage, or just purchase new linkage from Hasport for $140. The motor is a bolt-in swap for all 92-95 civics, 94+ Integras minus the transmission which would require a different mount and conversion to hydro.
The motor is a B18A1 pulled from a running and driving car that sat for a bit over a year due to a burnt out clutch and is the full long-block with wiring harness, Transmission is of the cable variety. Again The reason for sale is the clutch went out on it and the owner opted to replace the whole thing instead of just the clutch.
I'm looking for only $650 obo, and I will sell them separate $400 for the motor, 250 for the trans if desired. Local pickup preferred, I can deliver for a fee (Gas for a V-8 jeep) but I expect to receive payment for fuel before I deliver the motor. I'm located in Ottawa IL 61350, an hour east from Iowa on IL 80, an hour south of rockford on IL 39, and an hour west of Joliet also on IL 80
Mendez242
Jan 2, 2016 05:36 AM
Dasfinc
Jun 17, 2012 04:58 PM
Civic HX 121
Jun 10, 2012 07:13 PM
felipe69
Oct 19, 2007 04:11 PM
95civickid
14
Apr 22, 2005 09:15 PM
