almost done with my jdm h22 swap.. soooo?
Old May 14, 2008 | 09:48 PM
pkolaboy's Avatar
Default almost done with my jdm h22 swap.. soooo?
what do i do next... i already switched out the fuel rail....swapped the tranny... almost done with the wiring harness and vtec wiring... just seeing if i could someone that done a jdm h22 swap could give me some advice and some info on how their swap went...
Old May 15, 2008 | 05:18 AM
Acidcrakker's Avatar
Default Re: almost done with my jdm h22 swap.. soooo? (pkolaboy)
Im doing a swap now. So far this is my second one, and they never seem to go exactly as planned. I can get mine to turn on, but it doesnt want to stay on.
Old May 15, 2008 | 11:20 AM
pkolaboy's Avatar
Bump...
Old May 24, 2008 | 12:13 AM
218luder's Avatar
i too am doing a swap right now, from what a lot of people have told me is "double check your ground" , "make sure your wiring is correct". I just pulled my h23a about ready to swap parts to the h22 soon. hope you dont run into any problems
Old May 24, 2008 | 08:43 AM
cmwright1986's Avatar
dont forget to use the dizzy/external coil from your h23, unless you are planning on running the internal coil h22 one...
Joe Donohue
Feb 5, 2017 03:21 PM
persain488
Jan 18, 2011 07:16 AM
acclude23vtec
Oct 31, 2005 04:59 PM
iwhichisme
Sep 28, 2002 02:06 PM
