b16b pistons poor mans type r
hey guys well im just going to put it out there i got a poor mans type r (b18c block, b16 head) and i have skunk 2 prosires stage 1 cams, skunk 2 cams gears, bock manafold, b16b pistons, i guess im going to have to up grade my valve train going to get skunk 2 dual spring with retainers (i think skunk 2 at least) got a gsr tranny hirdo, 4-1 header, and i belive thats it well here is my quieston? i was going to resire fise my block and redeck my head to get me more conpresson but i dont know if im going to get pistons to valve slap be cuz of the such big dome on the b16b pistons so should i not resire fise them or just get one done or can i get a big gaskit to make up for it. thx eny thing u can help me with will help alot thx!! o yea and sorry for my spelling! o and its all going into a crx by the way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryon88 »</TD></TR><TR><TD CLASS="quote">resire fise </TD></TR></TABLE>
huh?
huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">
huh?</TD></TR></TABLE>
He means resurface or deck the block.
B16B pistons in a gsr block with a b16 head is a little much. The valves to piston clearence is gonna be redicluasly close. I have a gsr with b16 head and b16 pistons. compression around 11.5:1. If your looking to get really high compression then I would get aftermarket pistons because the valves reliefs are gonna be bigger so you don't have piston to valve contact.......oh yeah. If your doing a poor mans type R get the itr pistons. Valve clearence won't be so bad.
What?
In all seriousness....don't go with PCT pistons. The reasons NOT to use them are ALL OVER this forum. I'm not going to go into it. Wanna find out why, LOOK.
www.zealautowerks.com calculator shows a roughly 11:1 CR using JDM B16 (P30) pistons with a stock Headgasket. Same setup with a 2 layer HG yields 11.26:1. Play with the calculator and see roughly what you'd have to mill off the head to get your desired CR.
FatalCrixer
Apr 26, 2010 12:33 PM
eg92b16a2
Jan 15, 2006 07:54 AM
