just degreed my cams... dissappointed
Old May 14, 2008 | 07:51 PM
gsrturboEK's Avatar
Default just degreed my cams... dissappointed
just had my cams degreed... i lost HELLA power.. the tuner couldnt even get it close to where i was at when i first came in wut the heck is that all about? o and can someone please elaborate on wut is acutally done in degreeing camshafts? i just wanna if everything still line up the same wit the original marks for tdc.. crank and camgears.. thanks for any input
SETUP
H22A JDM
STOCK BLOCK
RM H24X
HOTSHOT HEADER
STOCK MANIFOLD STOCK TB
BEFORE 193 138
AFTER 174 130
Old May 14, 2008 | 08:09 PM
PyroProblem's Avatar
Default Re: just degreed my cams... dissappointed (gsrturboEK)
Is there a chance that maybe he didnt degree them properly?
Or perhaps wherever you had them before,the engine liked it more...
Degreeing the cams basicly times the cams to the crank more accurately than timing marks alone. This is the starting point for camshaft tuning,measuring,etc.
Normally, youd degree the cams,measure clearances,adjust,remeasure,and make final adjustments on the dyno...
In your case,sounds like the cams started in their ideal position and you kinda worked backwards...
Once the cams have been degreed properly,you should be able to tune them to at least where you started193/138, if not more...
Old May 14, 2008 | 08:30 PM
gsrturboEK's Avatar
Default Re: just degreed my cams... dissappointed (PyroProblem)
yea thats wut i thought too.. i was looking forward to at least picking up 5 hp from doing it.. but was left dissappointed.. so all adjustments r made on the cam gears?
Old May 15, 2008 | 10:09 AM
Aquafina's Avatar
Yes. Did you see him do it? If so, can you tell us what he did?
Old May 15, 2008 | 11:39 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
lol, surprised no one has mentioned you don't have NEARLY enough compression to really utilize those cams.
h24x on stock compression
Edit: also RM cams like to be rolled together when degree-ing. IE. advance or retard them together, not separately.
Old May 15, 2008 | 12:16 PM
Aquafina's Avatar
Degree'ing is not adjusting the cam timing as normal on the dyno.
Old May 15, 2008 | 12:19 PM
gsrturboEK's Avatar
Default Re: (Aquafina)
unfortunately we didnt stay to see wut they did becuz we had other things to take care of..
Old May 15, 2008 | 12:40 PM
BMo Tuning's Avatar
STAR
Those numbers are before and after degreeing correct?
Not before and after cam install?
All the marks should still line up the same. You move the cam itself inside the cam gear, the cam gear (the part with the teeth) stays still......so everything should still line up.
When you set your engine at TDC do the cam gears still line up like they should?
Old May 15, 2008 | 12:46 PM
SiB16A's Avatar
Default Re: (gsrturboEK)
MIDNIGHT PERFORMANCE of Sacramento They recommended it, and left with power loss
Old May 15, 2008 | 01:30 PM
Aquafina's Avatar
Did you give them the degree specs from Rocket?
Old May 15, 2008 | 01:33 PM
gsrturboEK's Avatar
they didnt even ask for specs.... but i messaged rocket afterwards n he said its fine at 0,0 if the head hasnt been milled
Old May 15, 2008 | 01:34 PM
BMo Tuning's Avatar
STAR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrturboEK &raquo;</TD></TR><TR><TD CLASS="quote">they didnt even ask for specs.... but i messaged rocket afterwards n he said its fine at 0,0 if the head hasnt been milled</TD></TR></TABLE>
Lol.........I'd stop taking your car there if they "degreed" in your cams without even asking for the specs to which they should be degreed. Set em back to 0,0 and if you really want to fool with the cam gear settings well do it on a dyno one degree at a time.
One other thing, I know every dyno is different but damn your tq is low for an h22.
Old May 15, 2008 | 01:43 PM
Aquafina's Avatar
Set them back to zero after taking pictures of the gears as they are now. If they didn't have the specs they didn't degree them. Then file a complaint with the BBB.
Old May 15, 2008 | 01:53 PM
gsrturboEK's Avatar
yea i dont know y my tq is so low.... thanks for all replys im gonan call them
Old May 15, 2008 | 01:58 PM
gsrturboEK's Avatar
just called him .. he said he had to find the degree specs himself... he gave me center line numbers of 103,106.. n when i bout the rocket cams.. i never got a cam card...
Old May 15, 2008 | 02:00 PM
b18avtec(A!!M0TOR)'s Avatar
man that sucks, just load the old map back in and set the cam gears back too 0,0 like everybody has mentioned.
Old May 15, 2008 | 02:03 PM
gsrturboEK's Avatar
Default Re: (b18avtec(A!!M0TOR))
already did.. but its kinda bullshit that i had to pay for the **** job
Old May 15, 2008 | 02:04 PM
Combustion Contraption's Avatar
Ask them what centerlines they installed the cams on. Post their answer.
Old May 15, 2008 | 02:08 PM
gsrturboEK's Avatar
Default Re: (Combustion Contraption)
answered above.. 103, 106 thanks
anyone able to find the specs for rocket cams ? i didnt get a cam card when i bought the cams.... thanks i saw them b4 but cant find them
Old May 15, 2008 | 02:09 PM
Ah, must have been a ninja edit. Anyway, Now we can wait for # verifications from one of Rockets reps.
Old May 15, 2008 | 02:10 PM
gsrturboEK's Avatar
i believe it was 101 103 when i saw it the other day but gotta get it confirmed...
Old May 15, 2008 | 03:24 PM
phatrick2332's Avatar
This might be a stupid question, But what are the chances they made piston to valve contact in the process and didn't say anything to you? I may be completely wrong, but it came to mind.
Old May 15, 2008 | 03:40 PM
lunatics209's Avatar
midnight..???? dude u r out of your mind going there.
Old May 15, 2008 | 06:54 PM
1 2 NV's Avatar
Default Re: just degreed my cams... dissappointed (lunatics209)
degreed or not i think somethings wrong inside your motor. whether it be bent valves or any amount of other things.
Old May 15, 2008 | 07:46 PM
soulpwr's Avatar
Default Re: just degreed my cams... dissappointed (1 2 NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">degreed or not i think somethings wrong inside your motor. whether it be bent valves or any amount of other things.</TD></TR></TABLE>
I'd guess slightly bent valves.
