warped head????
Old May 14, 2008 | 07:01 PM
jlopez88's Avatar
Default warped head????
ok today i replaced my headgasket on my d16y8 because it was leaking oil from the front corner by the distibutor.. well i get the head off and replace the head gasket and its still leaking i really dont know what it is because the motor still has good compression like if i get on it it doesnt lag or anything just like if nothin were wrong please help me out here im stumped
Old May 14, 2008 | 07:14 PM
elektronsi's Avatar
Default Re: warped head???? (jlopez88)
have you done a compression test? also do you have coolant in your oil? check all gaskets on the top end
Old May 14, 2008 | 07:16 PM
MONSTERZC's Avatar
Is the oil running down to the corner or is it leaking from the bottom of the head. It could be the distibutor o ring.
jlopez88's Avatar
Default Re: warped head???? (elektronsi)
no it runs fine like nothin is wrong at all but u can see the oil on the side of the block on the corner by the distributor
Old May 14, 2008 | 07:18 PM
jlopez88's Avatar
its like on the corner but i cant tell exactly where it is comin from and it might be the dizzy o-ring but i didnt think to check it how would i be able to tell if it is bad or not?
Old May 14, 2008 | 07:23 PM
MONSTERZC's Avatar
Default Re: (jlopez88)
Clean the area real good. watch the distibutor where it meets the head. ( start car) if it leaks replace if not keep searching till you find it.
Robotin
Mar 24, 2012 04:03 PM
Ryan559
Dec 22, 2010 09:43 PM
grizzy225
Aug 6, 2007 07:48 AM
turbo gsr
May 28, 2007 06:20 AM
P@@RB@Y
Jan 20, 2006 01:19 PM
