audio for sale
Kenwoood KAC-7202
Details:
• two-channel car amplifier
• 150 watts RMS x 2 at 4 ohms (230 watts x 2 at 2 ohms)
• 460 watts RMS x 1 bridged output at 4 ohms (4 ohm stable in bridged mode)
• high-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
• selectable bass boost (0-18 dB at 40 Hz)
• cooling fan
• MOSFET power supply
• Tri-way capable (Tri-Way crossover required)
• CEA-2006 compliant
• preamp- and speaker-level inputs
• preamp outputs
• fuse rating: 40A x 1
• 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
• 15"W x 2-7/16"H x 11-5/16"D
• warranty: 1 year
• Want more peace of mind
Kenwood KAC-8402
• 4-channel car amplifier
• 60 watts RMS x 4 at 4 ohms (90 watts x 4 at 2 ohms)
• 180 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
• front channel high-pass filters (50-200 Hz at 12 dB per octave), rear channel high- and low-pass filters (50-200 Hz with 12 dB/octave high-pass and 18 dB/octave low pass)
• bass boost (6 dB at 90 Hz), channels 3 and 4
• preamp outputs
• requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
• warranty: 1 year
2 Rockford Fosgate P215S4 12inch in a box
Sensitivity: 87.5 dB
RMS Power Range : 50-250 Watts
Peak Power Handling: 500 Watts
Impedance: 4 Ohm
Low Frequency response: 20 Hz
High Frequency Response: 200 Hz
Diameter: 15 Inch
Features
molded polypropylene woofer cone
60-ounce magnet
4-ohm impedance
top-mount depth 7-3/16"
sealed box volume 2.25 cubic feet
ported box volume 2.50 cubic feet
Priced per speaker
and 4 6'9
Sony XS-S690CX
top Mount Depth: 3-1/8 Inches
Bottom Mount Depth: 3-1/8 Inches
Sensitivity: 92 dB
RMS Power Range : 80 Watts
Peak Power Handling: 320 Watts
Impedance: 4 Ohm
Frequency response: 25-30000 Hz
Design: 2 Way
Woofer Composition: HOP/Paper/Film
Diameter: 6x9 Inch
Features
Stroke Stabilizer Surround
6 x 9" HOP Woofer Cone
2-9/16" cone midrange
Magnet Material: Ferrite/Ferrite/Piezo
Cone Material: HOP/Paper/Film
Mounting Depth (inch): 3-1/8
Mounting Diameter (inch): 8-5/8 x 5-7/8
Mass (lb/oz): 2/14
Nominal Imp (Ohms): 4
this is all coming out of my truck.... components sold already........ I want to sell hole. no parting out..... taking offers for the whole thing...wires and speakers wires are included
