need a manual
Old May 14, 2008 | 05:02 PM
90hatchhill's Avatar
Default need a manual
so i have a 90 civic hatch with the 1.5 SOHC, which is burning oil like crazy so i happened to come a across a another hatch exactly the same but with a b16a and an lsd 5 speed. that car is wreaked but the engine is good, plan is to swap the engines.
im starting to dig in to it and feel like it over my head i need a good shop manual. anyone know witch one and where to get it?
Old May 14, 2008 | 05:30 PM
grog's Avatar
Default Re: need a manual (90hatchhill)
The official honda/acura manual is the Helm manual. Expensive but priceless
there are also some online manuals, look in the FAQS
if you plan on swapping a B16 in then you might want one for the civic and a manual for the motor also
also if you plan to swap that motor just look through the faqs at the top of the civic/crx page, theres alot more relavant swap info there.
https://honda-tech.com/zerothread/1508680
btw that project should be fairly straight forward. just take the motor mounts wiring harness, ECU, axels and hubs if you need them, and exhaust (just so it fits) from the other car.
While you have the motor removed you should do some preventative maintanance like the water pump and timing belt, ect.
Old May 14, 2008 | 06:09 PM
draperj09's Avatar
Default Re: need a manual (grog)
Just search man. There's TONS of B16 swap guides. On Honda-tech and off honda-tech. Google it when your done on here. And check out 10 different sites.
taeim
Dec 27, 2007 10:54 PM
.I.Need.Money.
May 25, 2006 11:44 AM
moshboards
Aug 29, 2004 12:57 PM
sak
Aug 10, 2004 11:35 AM
Short_Shifter
Jan 24, 2002 08:38 PM
