manifold for a TIAL stainless housing
This one is a *******(&*(!!!
Ive got 3 inches from exhaust ports to turbine flange. Not much room to work with!!
Tials Vband housing is the sh%T!!! Knocks the wieght of a 35r from 17 lbs to 12 lbs!!
Modified by NLR at 7:07 AM 5/15/2008
its suzuki 1.3 liter engine.
Dave,
this is with a miller. I use the htp for all the aluminum and miller for stainless etc.
1 pass now. cup
155 amps
8 cup
3/32 2%
30 degree
Dave,
1 pass now. cup
155 amps
8 cup
3/32 2%
30 degree
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by random_tuner »</TD></TR><TR><TD CLASS="quote">Round ports, almost like its for a bike.
What application is this for? It looks pretty good so far! Good welds. Are you running 2 passes or just 1?</TD></TR></TABLE>
Indeed. This guy builds some badass F*&#in bikes.
Post up pics of the bike if you have any!!!
yes I hit the pieces with a roloc disc before welding.
Here is our race bike 645 hp at 34 psi
Tial sport gt35r
Tial Q blow off valve
Tial 44 mm gate
On 22 psi it goes
7.30 at 200 mph
runs 4.82 in the 1/8 at 163 mph
This header Im building will be used on a similiar set up except it will have 2 intercoolers , 1 on each side! That way I can lean if I need to without skidding across the track
Modified by NLR at 6:18 AM 5/18/2008
Tial sport gt35r
Tial 44 mm gate
On 22 psi it goes
7.30 at 200 mph
better angle than coming into the 2 and 3 from the sides. Since its so short to turbine flange the joints(splayed area) of 2 and 3 is high. Combining 1 and 4 into this area would mean that all cylinders are combining above the flange which isnt the best for overall set up. Any header I build will only allow 2 cylinders to meet above the turbine flange. Direct and and move the point of impact of exhaust gas as close to the turbine wheel as possible.
Just the way I do things
if i took some of those dick pills they try to sell on the t.v. thus making my ***** grow three times bigger than they are, they'd still be half the size it takes to ride that 650hp busa.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NLR »</TD></TR><TR><TD CLASS="quote"> Direct and and move the point of impact of exhaust gas as close to the turbine wheel as possible.
point of impact? i dont understand... can you explain the point of impact better? i thought the only thing to worry about was pressure and flow?
Where they combine there will be turbulence. Do you want that to happen 2 .5 inches away from your exhaust ports or as far away from the exhaust ports as possible and as close to the turbine wheel as possible? Directing exhaust pulses to take maximum effect of the energy available.
Here is an example of a header I made. Worked decent.....If you notice all 4 cyl combine way above the flange.
This next header improved spool and picked up power! 1/2 does not combine with 3/4 until after the turbine flange.
Modified by NLR at 5:07 AM 5/19/2008
looks great! you might want to check out the tight radius bends that acestainless sells.... I know a tighter radius wont be better for flow, but it may allow you some freedom you didn't have with the wider radius bends. Looks great either way!
I personall think a cross between this manifold...
and your current manifold would be optimal. You would decrease runner volume (shortening spool time) and might be able to make more power by having the (exhaust flow) runners enter the turbine inlet tangent to the flange. However...it is nice that the SS TiAL housing is MUCH lighter and compact!
Great looking piece and amazingly fast times.
