Driverside window goes up and starts popping until you let off the switch
Seems there is a limit switch bad or something. When the window gets all the way up it starts popping like it's out of gears or something.
Anyone know exactly what's wrong with the window? Almost sounds like it's stripped at the top.
Replaced the regulator yesterday. The old one was stripped on the top 4 teeth of the regulator. After taking the door panel off, it looked like someone had tried to adjust the regulator before to make it work better, but never replaced it correctly. Now it works good. Also replaced the window switch while the panel was off. My old one literally fell apart when I removed it. It was all busted up. Now I have a auto-down window again.
jerBEAR
Honda Civic (2001 - 2005)
Sep 6, 2010 06:11 PM
hondapwr
Jul 17, 2009 05:30 PM
