Sol bogging down at low RPM
Here's the deal:
At low RPM, the car car will shudder and bog down a bit, and occasionaly cut off. At idle and in higher RPM it runs fine.
The dizz cap, rotor button, and entire dizzy are new. Including the ignition module and coil.
I'm thinking its a feul issue... any ideas?
Try checking your TPS sensor. I had a very similar problem after troubleshooting a previous one. I took my TPS off and had put it back on with the TPS clip off the throttle prong and caused it to run like that. Or your TPS could just be bad. Any way good luck.
gokus-eg2
May 21, 2012 09:21 PM
Al_90HB
Dec 3, 2010 01:54 PM
