VTEC switchover
OK, where would you seggest I have my VTEC kick in and off if I'm having the ECU rechiped? It's going into a '93 Civic HB with a JDM B16A2.
keep it stock unless u have aftermarket cams, only time i would change vtec crossover is to put on the dyno and tune the thing to the smoothest dyno climbing on the chart.
this is why i don't understand vtec controllers, why do that unless you constantly change things in ur motor, or constantly changing pounds of boost on a turbo.
other than that, HTH
[Modified by poison, 9:39 PM 7/14/2002]
