Stuck Caliper Piston
Old May 14, 2008 | 12:37 PM
g2tegsown's Avatar
Default Stuck Caliper Piston
Alright so I went out yesterday and put new front pads on my CRX, I have never done this before so I had some help from a friend. When we pushed the caliper piston in, brake fluid came out of the master cylinder and dripped all over, same with the other side. I cleaned it all up and then tested out the new pads, everything was fine.
So today I go out to do the rear pads, I get to the point where I have to push the piston in, and it won't even move. So I go out and buy a tool that spreads the caliper and it doesn't even budge it either (It was a cheap POS one, but it was the only one they had). Is there something I am not doing? Because this thing is SOLID, the piston will travel out farther when the brakes are applied, but will not go back in, so I don't think it's seized. I wasn't having any braking problems to my knowledge other then the pads were old and worn, and the pads were worn evenly.
Any ideas? Cause I am losing my mind
BTW this is the SI with all disc brakes.
Old May 14, 2008 | 01:13 PM
kacivic's Avatar
is your piston slotted, or does it have notches? for some reason, every rear caliper i've encountered you have to turn the piston clockwise to retract it. i got a universal 6-sided tool (different slot pattern on each of the 6 sides) that you use with a socket wrench at auto zone pretty cheap for just that purpose.
Old May 14, 2008 | 02:12 PM
7PSI CRX's Avatar
Default Re: Stuck Caliper Piston (g2tegsown)
Yes, the rear caliper piston needs to be turned & be pushed in at the same time.
Old May 14, 2008 | 04:50 PM
ahglaze1's Avatar
Default Re: Stuck Caliper Piston (7PSI CRX)
if u just get a big flat head srewdriver it works and turn clock wise dont for get that or u will have a heck of a time gettin the piston back into the caliper
Old May 14, 2008 | 05:10 PM
MoreBoost!'s Avatar
Default Re: Stuck Caliper Piston (ahglaze1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kacivic &raquo;</TD></TR><TR><TD CLASS="quote">is your piston slotted, or does it have notches? for some reason, every rear caliper i've encountered you have to turn the piston clockwise to retract it. i got a universal 6-sided tool (different slot pattern on each of the 6 sides) that you use with a socket wrench at auto zone pretty cheap for just that purpose.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">Yes, the rear caliper piston needs to be turned & be pushed in at the same time.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahglaze1 &raquo;</TD></TR><TR><TD CLASS="quote">if u just get a big flat head srewdriver it works and turn clock wise dont for get that or u will have a heck of a time gettin the piston back into the caliper</TD></TR></TABLE>
Old May 14, 2008 | 05:12 PM
g2tegsown's Avatar
Thanks so much guys! Thats was the trick
Dann6968
Suspension & Brakes
Mar 7, 2010 07:51 PM
FlyZlow
19
Jan 23, 2005 01:01 PM
mjrage
Aug 19, 2004 07:56 PM
classciv
Jun 25, 2004 04:07 AM
harryg
Feb 13, 2003 05:05 AM
