Fuse spot is too big
1 of the fuse spot under the dash is too big, the fuse terminals doesn't meet up with the car terminals, somebody used some type of spacer to stretch it, any way to get it back to normal?
yeah its the right kind of fuse, you know if you take the fuse out theres like metal things in there that holds the fuse in? mines is stretched, i guess the only solution is foil??
Can you pull the fuse box out and try to bend those terminals back into place?
I wouldnt put foil in there, because if the fuse blows, and you actually have a problem, its a fire hazard.
