ls header help???
Old May 14, 2008 | 04:16 AM
91jdmhatchback's Avatar
Default ls header help???
ok well i have a b18a1 motor i'm puting together for my dd. and i'm eather looking at using my cast ls manifold or build a header. now i'm more then capable of fabricating and welding a tubular header together.
my main question is i have no clue the breathing needs of my motor and the last thing i need is to make a header that is to big, small etc...
now i'm not aking for build plans so to speak ( not that i would expect that or want that). but i'm more looking for a good start to work off of.
specs:
81mm b18a1 w/ pr3 pistons, (11.4:1)< zeal auto comp. calculator, stock head/cams, modded gsr intake manifold/t body, stock gsr intake, and a 2.5" header back exhaust.
only thing i will be getting in the future will be a set of crower 404's and valvetrain.
ok guys lmk what you think
Old May 14, 2008 | 09:56 PM
anybody???
Old May 15, 2008 | 02:32 AM
Default Re: (91jdmhatchback)
seriously there used to be ppl who helped answer questions....
Old May 15, 2008 | 04:38 AM
gibsanez's Avatar
If you actually want to make power out of a non-vtec B18 (which can be an uphill battle), then I would seriously leave the the header to the professionals, who makes the things for a living.
Old May 15, 2008 | 05:48 PM
Default Re: (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">If you actually want to make power out of a non-vtec B18 (which can be an uphill battle), then I would seriously leave the the header to the professionals, who makes the things for a living. </TD></TR></TABLE>
well i know im not going to master making n/a headers over night here ppl.
but i'm more then capable of making a header as i make turbo manifolds and related peices daily, it is my job. with that said it is pretty hard for me to spend $600-1000 on a custom header from one of the known companies, when i know i can do similer work for cost of matarial and my time.
so with that said i'm not looking for a step by step diy. i just want to know where to start, like tube size and legnth for primary and secondary. i can figure out the rest from that.
also what would be a better layout 4-1 or 4-2-1?
Old May 16, 2008 | 04:20 PM
anyone????
Old May 16, 2008 | 09:15 PM
Top Ramen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback &raquo;</TD></TR><TR><TD CLASS="quote">
In theory, the 4-2-1 headers should make more torque, at the expense of some top end, but in real life, you are not going to see the advantage of that design on a motor like that. They work great on V8s, but small motors make power by reving and 4-1 headers make more power at higher rpms. Yes, I know its an LS, not a B16, but it is still a small motor in the overall scheme of things. Go with a 4-1.
As for the tube diameter - you must know someone with a decent header; throw a caliper on there and see what the pipe diameter is.
My .02.
Best of luck with your project.
EDIT --&gt; if you do go with a 4-2-1, copy the HyTech layout which makes the 'Y' really looooong. Again, small motors rev to make power and they like the long tube exhausts.
Modified by Top Ramen at 10:09 PM 5/30/2008
Old May 18, 2008 | 12:51 AM
Default Re: (Top Ramen)
thanks ramen...
yeah i thought about measureing tube diameter. but primary and secondary length is what i'm stuck on.
r33dm0n3y
14
Jun 11, 2009 08:11 PM
91jdmhatchback
Welding / Fabrication
May 16, 2008 04:18 PM
aznboi_2
Oct 25, 2006 01:07 PM
ORANGE EF
Mar 26, 2006 04:25 PM
Type RS
Feb 9, 2003 08:26 AM
