SPUN ROD BEARING 2nd cylinder b16asir2
Old May 13, 2008 | 06:23 PM
elwuudz2's Avatar
Default SPUN ROD BEARING 2nd cylinder b16asir2
WTexplitive
Please explain the damage that might result from a spun rod bearing
How extreme would the damage have to be to replace with a new bottom end
also how feasable is putting a b20z in place of the b16 with p30 pistons with a stock head and no hondata or tuning
Old May 13, 2008 | 06:25 PM
Combustion Contraption's Avatar
Open it up and find out. No one in here has a crystal ball to gaze into the insides of your sealed engine with sorry.
Old May 13, 2008 | 07:10 PM
elwuudz2's Avatar
Default Re: (Combustion Contraption)
I will post up detailed pictures of everything tomorrow
Old May 13, 2008 | 07:12 PM
Default Re: (elwuudz2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwuudz2 &raquo;</TD></TR><TR><TD CLASS="quote">I will post up detailed pictures of everything tomorrow
Atta boy! Once we have detailed pics (not blurry cell phone pics) we can help assess the damage with some of the trained eyes we have on here. You have withstood the initial dickheaded comment, and taken the advice given. Good job. I will put you on my "help" list.
Old May 13, 2008 | 07:22 PM
elwuudz2's Avatar
If in fact the components are too marred or warped
A b20z bottom end:: CRVTEC might be the result; im prepared for another rebuild
I'm currently re searching all the non sleeved builds
Please provide additional do's and don't if you have the experience
Will a b20z run smoothly with a stock b16a sir2 head with a light flywheel?
Old May 13, 2008 | 07:45 PM
mar778c's Avatar
Community Builder
Community Influencer
P30s won't work in a B20, 81.XX piston diameter vs 84 mm bore. You will need a 84 mm piston.
V3ND3TTA
11
Aug 31, 2008 03:31 PM
mrsideways
Dec 5, 2007 10:08 AM
jakedoza
Jul 20, 2005 10:15 PM
90civichb
May 4, 2004 05:34 AM
