90 crx hf no spark
Old May 13, 2008 | 06:18 PM
Scott424's Avatar
Default 90 crx hf no spark
Ok this has me completely stumped. . . i spun a bearing on my A6 that i swapped in and car still ran when a parked it it just knocked really bad so i bought another used a6 and in im not getting spark ive replaced the main relay and ive put a dizzy that i know works on it along with another ecu and i cant get spark.I did a wire tuck on only the driver side while she was out of commission could one of my wires came loose and be causing this ? any help would be much app :
Old May 14, 2008 | 07:47 AM
jlicrx's Avatar
Default Re: 90 crx hf no spark (Scott424)
are you using the HF engine harness? A6 engine harness will not work with HF chassis harness
Old May 16, 2008 | 05:53 AM
Scott424's Avatar
Default Re: 90 crx hf no spark (jlicrx)
It actually was not. i put the hf harness on last night and put a new coil on and got it to fire and run but i shut it off cant get it to run again. it has strong spark at first then it seems like it dies out any ideas ?
hondaex99
Oct 29, 2009 09:19 PM
Turbo EH2
Sep 28, 2006 09:21 PM
ek_b16
Oct 16, 2005 05:47 PM
paulzy
Jun 21, 2003 03:34 AM
