94 COUPE K20 TURBO LOTS OF MODS!!!!!
Old May 13, 2008 | 02:07 PM
caitlinsbabyboy's Avatar
Default 94 COUPE K20 TURBO LOTS OF MODS!!!!!
I have a 94 civic coupe power everything but sunroof! Need to get rid of asap located in SC! The whole car has been rewired to 04 wiring and it has the 04 ep3 dash in it out of the SI! Only had 1000 miles put on with turbo kit!
no ac but heat could be hooked up just with the heater hoses!
320whp 285ft/lb torq at 10 psi! MAKE OFFER NOT WANTING TO PART OUT!
38000 miles on motor and dash! Unknown on shell but all new bushings!
MOTOR:
-K20A3 WITH LIKE 38000 MILES! oil changed every 500 miles!
-K20A2 TRANSMISSION MINT NO GRINDS!
-XTD pro-lite racing flywheel!
-ACT 6 puck non-sprung clutch with xtreme pressure plate!
-Golden Eagle Fuel Rail Black!
-RC 550cc fuel injectors!
-Aeromotive Fuel pressure regulator with steel braided hoses!
-NRG Carbon fiber intake cover!
-Drive Shop 350hp axles!
-Golden Eagle Head Studs(not installed) not needed unless boosted over 15 psi in which rc 550cc injectors will need to be upgraded to 1000cc!)
-Intercooler 28x9x2.75 with black intercooler piping!
-Cast top mount t3/t4 turbo manifold with 70trim t3/t4 turbo!
-Custom 2.5" exhaust ran to muffler!(NOT THE BUMBLEBEE CRAP!!)
-35mm wastegate 10lb spring
-HKS ssqv BOV
-the stock diff has been worked on so that both wheels grip!!
-Hasport Egk20 mount kit!
-RSX Radiator!
-NGK turbo plugs!
-HONDATA K-PRO WITH ECU PLUG IN GLOVE COMPARTMENT
Interior
-Custom fit with the 04 civic si dash!(ONLY EG IN THE WORLD WITH THIS!!!!)
-04 si steering wheel and immobilizer key
-triple gauge pillar
-AEM TRU-BOOST
-AEM WIDEBAND UEGO complete
-CUSTOM center console with 6x9 in rear
-Floorboard modified for 04 dash and 04 si center console!
-Custom 6x9 box in back glass with 3-6x9!
-Custom blue and black suade seats with blue inserts!
-Custom door panels- Black vinyl with red stitching and 04 si switches and
handles!
-Blue LEDS when trunk is opened!
STEREO
-Pioneer CD PLAYER
-1600w boss 4-channel amp to power the highs!
-2000w powerbank 2-channel amp to power subs!
-3-sony 1300w 12inch subs with custom fiberglass box!
-2.5 farad power cap!
-4-6x9 pioneers
-2-5.5" pioneer door
EXTERIOR
-BC2 rear bumper molded
-BC2 side skirts molded but there is a support bar welded on the bottom of
the frame to keep from being cracked loose!
-BC2 front bumper
-DARK FIJI BLUE EFFECT PAINT JOB!(roof needs repainting someone
scratched it)
-7 color LED undercar lights!
-Chrome LED door handles!
-SI wheels with michelin exalto tires also have a set of MT drag slicks if
price is right!
-JDM crystal clear taillights
-1 piece JDM halos!
SUSPENSION
-SI Rear disc conversion
-EX Front disc conversion
-BREMBO drilled and slotted rotors
-Coilovers
PICS AT http://www.hondamarketplace.com/zerothread/2293132
Modified by caitlinsbabyboy at 9:35 PM 5/18/2008
Old May 13, 2008 | 03:42 PM
chadalac1712's Avatar
holy ****...thats all i gotta say...beautiful car!
Old May 14, 2008 | 05:42 PM
Default Re: (chadalac1712)
thanx! somebody needs a new car! make me offers let me know what you got and we might can work something out!
Old May 16, 2008 | 02:16 PM
bump!
Old May 18, 2008 | 08:31 PM
8500 and its yours!
Old May 25, 2008 | 06:15 PM
come on guys this is the last offer 7500 or i will let it sit!!!!!
Andr3w
Aug 22, 2009 05:24 AM
caitlinsbabyboy
May 29, 2008 08:54 PM
OrangeBoost
Canada (Sales)
Oct 12, 2006 07:27 PM
TurboLude97
Jun 10, 2006 04:09 PM
