rsx turbo
Old May 13, 2008 | 11:19 AM
jdmjin's Avatar
Default rsx turbo
im going to turbo my rsx.....but i need to know how the car runs without a engine management?.....bc i currently dont have one.....i also need opinions on which one to get... and i know that everyone is going to tell me hondata....but i need to know if theres others and if they are expensive?
Old May 13, 2008 | 11:20 AM
chimmike's Avatar
Default Re: rsx turbo (jdmjin)
if no engine management, don't go turbo, period.
FAQ's are your friend dood.
Old May 13, 2008 | 10:13 PM
jdmjin's Avatar
yea i know...but i want to know if anyone has gopne turbo without an engine management? i wont be boosting more than 5psi, for the meantime....
Old May 13, 2008 | 11:30 PM
oodie's Avatar
Blown up k20
Old May 14, 2008 | 05:30 AM
chimmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjin &raquo;</TD></TR><TR><TD CLASS="quote">yea i know...but i want to know if anyone has gopne turbo without an engine management? i wont be boosting more than 5psi, for the meantime....</TD></TR></TABLE>
Like I said. No engine management, no turbo. If you don't want to do it right, don't do it, or risk blowing your engine.
Old May 14, 2008 | 07:46 AM
GT35R_EF's Avatar
Make mine whatever you want
Default Re: rsx turbo (chimmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">
Like I said. No engine management, no turbo. If you don't want to do it right, don't do it, or risk blowing your engine. </TD></TR></TABLE>
Yep, save up and buy the kpro. Yes it is expensive, BUT you make the choice if it is worth saving your car. It's crazy how people will spend so much on so many parts and not anything on an EMS.
Old May 14, 2008 | 07:53 AM
Glove's Avatar
Default Re: rsx turbo (GT35R_EF)
dude, you cant boost without engine management, how is your ecu gonna know what to do with the boost?
youv got a LOT of research to do.
Old May 14, 2008 | 07:54 AM
90blackcrx's Avatar
Who needs engine management when you have a fpr.
Old May 14, 2008 | 07:56 AM
morgan@synapse motorsport's Avatar
the oem computer has no way to provide anything close to accurate fueling and ignition for the turbocharger. when the ECU sees a positive pressure from the map sensor there is no values because the ECU has no maping for it. it thinks the map sensor is broken. without the extra fuel needed, and without ignition timing taken out for the added airflow will kill that motor very quickly even at 5psi.
K pro is the best way to tune an RSX on boost. its not a bad price for what you are getting, a standalone ECU with a lot of excellent features.
Old May 15, 2008 | 11:20 AM
jdmjin's Avatar
Default Re: rsx turbo (mike@synapse motorsport)
thanks guys for all the info....very helpful...the only reason is bc i turbo my friends b20 and its running at 4 psi with no tuned ECU (Yet he is working on getting a p28)....but it seems to run fine...also i have a friend with a 2000 civic and my friend put a turbo from a ford probe....and hes been running his car the way it is for the past year (its doing 5psi)...thats y i had to ask about the k20. i got my turbo kit already, i just need the kpro. Does anyone know where i can find one for decent prize?
Also would the reflash work?...its the cheaper version that hondata makes for the k20?
EduardoDC5
Jan 30, 2007 04:55 PM
wish_i_was_h22a
Sep 2, 2006 06:14 PM
dinku27
Sep 15, 2005 01:34 PM
DenizenSays
Sep 21, 2004 03:36 PM
