LEAKS
Old May 13, 2008 | 11:09 AM
krazy one's Avatar
Default LEAKS
when building your motor up and tuning, what are some leaks you came across with? how did you fix it, how bad was it, how much of a pain was it? what are some common leaks?
someone told me when you go FI you come across more leaks than all motor, but the way i look at it, leaks just happen. period.
Old May 13, 2008 | 11:26 AM
vtecb18c's Avatar
Default Re: LEAKS (krazy one)
if you do it right you shouldn't have any leaks..obviously no one is perfect and every time I've put an engine together I've always had some small leak...it could be anything from a lose oil line or fuel line to bad seals/gaskets...valve cover gasket seams to be a typical headache or oil pan gasket....lose rad hoses can make a nice mess
Old May 13, 2008 | 11:40 AM
Red Balut's Avatar
cam seal are infamous for leaks. if encountered, dab a lil hondabond around the rubber ring when installing a new one. or replace it with a double or triple ring cam seal w/ hondabond.
Tong.Y
Jul 4, 2011 08:16 PM
danielblushtein
Mar 16, 2009 12:33 PM
itzyaboyzeem03
Nov 2, 2008 01:47 AM
Gomdohree
Apr 27, 2008 11:09 AM
CO_CReX
Jan 30, 2006 06:59 PM
