hard braking causes stalling?
Old May 13, 2008 | 10:49 AM
JunCB7's Avatar
Default hard braking causes stalling?
Why does my car stall out when i come to a hard stop?
Old May 13, 2008 | 11:38 AM
chris_d's Avatar
Default Re: hard braking causes stalling? (JunCB7)
Cant explain why it happens but mine was fixed by having the valve tappets adjusted correctly by a honda dealer.
Old May 13, 2008 | 12:05 PM
hondadude's Avatar
The brake booster uses a lot of vacum.
If you are sitting at idle and step on the brake does the idle drop a couple hundred RPM?
If that happens check for vacum leaks
Old May 13, 2008 | 05:48 PM
JunCB7's Avatar
Default Re: hard braking causes stalling? (hondadude)
Yea that is exactly what happens. Me and my friend checked everything and nothing seems disconnected or leaking.
Modified by JunCB7 at 9:45 PM 5/13/2008
Old May 14, 2008 | 06:53 PM
JunCB7's Avatar
btw I have the h22a
Redprelude98
25
Nov 30, 2014 02:15 PM
stripes777
Apr 27, 2008 02:34 PM
RACEPAK
Nov 23, 2006 01:33 PM
civlude
Aug 19, 2006 01:55 PM
smithbling
Mar 13, 2003 03:49 PM
