what kind of injectors should i use
Old May 13, 2008 | 08:24 AM
civacman's Avatar
Default what kind of injectors should i use
i have a 95 gsr with a crower stroker kit with 11:5:1 pistons,built valve train with stock cams 4 now i dont know what injectors to run i want to also run spray later
Old May 13, 2008 | 10:36 AM
prettylew's Avatar
go with 440cc RC injectors.
you can always tune injectors down. but if you buy too small and max them out your screwed.
Old May 13, 2008 | 04:39 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: what kind of injectors should i use (civacman)
What does your tuning software say? are your stock injectors maxed out? Spray doesn't matter if you're using a wet kit (smart choice).
Old May 15, 2008 | 10:37 AM
civacman's Avatar
Default Re: what kind of injectors should i use (00Red_SiR)
the injectors r venom but the guy that put the motor together said they r 310cc i calld venom n venom said they r stock injectors bored out thanx 4 the comment i am gonna go with rc 440s
A13sechatch
Mid-Atlantic (Sales)
May 25, 2009 08:26 PM
doodooheadfart
Feb 22, 2007 09:53 PM
mprelude
Nov 27, 2004 03:25 PM
