Difference between GSR and LS injectors
Old May 13, 2008 | 06:30 AM
schpiel's Avatar
Default Difference between GSR and LS injectors
I need a set of fuel injectors for a B18b that I am about to swap in my car. I am using the P75 ECU from the Ls Integra, and I was wondering if it will work, and function properly if I use GSR Integra injectors instead of Ls ones? I would have searched but the search function seems to be down, I think it was a while ago also. Anyway, I am sure this is a quick question, so if anyone knows the answer, please help out.
Thanks
Sean
Old May 13, 2008 | 07:17 AM
bap168's Avatar
Default Re: Difference between GSR and LS injectors (schpiel)
same
Old May 13, 2008 | 08:03 AM
kaiba's Avatar
Default Re: Difference between GSR and LS injectors (bap168)
Same ****!
Old May 13, 2008 | 08:17 AM
Relic1's Avatar
exact same flow rating, same part numbers if in the same OBD series. (ie OBD2b, OBD2a or OBD1)
Old May 13, 2008 | 09:40 AM
schpiel's Avatar
Default Re: (Relic1)
Sweet!!! Thanks for the help guys, now I know something I didn't..haha!
B_Swapped93
Mar 9, 2013 02:51 PM
snowpro127
Nov 18, 2009 06:57 AM
Heretic:Si
Mar 8, 2007 02:09 PM
boosted 95 coupe
Aug 9, 2006 01:11 PM
Hunter_EL
Sep 21, 2001 09:22 AM
