Mid-Atlantic (Sales) VA, DC, and MD
SRP/JE D16Z6 75mm stock bore, 9.0:1 forged pistons and rings NEW in box. FAIRFAX, Virginia
Old May 13, 2008 | 05:54 AM
hybridmoments's Avatar
Default SRP/JE D16Z6 75mm stock bore, 9.0:1 forged pistons and rings NEW in box. FAIRFAX, Virginia
(brand new, unused. will fit in Y8 or Z6. in a Y8 engine these will give you slightly more then 9.0:1 compression) Rings have not been filed. $320 Shipped $310 in person
These are a great choice for a stock bore D series engine. the Piston to wall clearnace required for boost will give you enough room to hone your block if you want.
if you get vitaras, they require a much lower piston to wall clearance since they are a cast piston. your piston to wall clearance will most likely be too high with a Vitara in a stock 75mm bore. your engine is going to sound like a diesel truck there will be so much piston noise.
You really have to go to a 75.5mm vitara and then have your block bored & honed for correct Piston to wall clearance. which adds another $200+ to your costs.
Old May 15, 2008 | 04:40 AM
Default Re: SRP/JE D16Z6 75mm stock bore, 9.0:1 forged pistons and rings NEW in box. FAIRFAX, Virginia (hybr
bump.
can't beat this price. these go for $450 on ebay.
hybridmoments
Aug 13, 2008 05:29 PM
methos713
15
Jan 10, 2008 06:26 PM
n20sol
Jul 2, 2005 06:34 AM
siis2fast
Jun 7, 2005 03:52 AM
Hybrid
May 31, 2002 07:49 PM
