lsvtec ????
Old May 12, 2008 | 09:18 PM
madjdmek9's Avatar
Default lsvtec ????
ok so i got an fullybuilt lsvtec. runs good but the vtec is not popping.and when it gets to 51k were vtec supp to hit it leeks oil.and i have no freaking clue were the hell its coming from.sucks not having vtec and leeking oil from behind the motor.leeks down to headers were the o2 sensor is at. anyone have a clue?
Old May 12, 2008 | 09:25 PM
ReactioN's Avatar
* B A N N E D *
Default Re: lsvtec ???? (madjdmek9)
Head Gasket?
Old May 12, 2008 | 10:00 PM
cherroneballs's Avatar
If your leaking oil you may not be getting enough pressure to the head to make vtec crack.
Old May 13, 2008 | 11:33 AM
wmac's Avatar
is it leaking from where the vtec solenoid should be?
Old May 14, 2008 | 09:56 AM
madjdmek9's Avatar
Default Re: (cherroneballs)
yeah thats what i was thinking. should i change out the oil lines? or is it the oil line sensor ?
Old May 14, 2008 | 09:57 AM
madjdmek9's Avatar
Default Re: (wmac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wmac &raquo;</TD></TR><TR><TD CLASS="quote">is it leaking from where the vtec solenoid should be?</TD></TR></TABLE>
naw not from there.
Old May 14, 2008 | 10:19 AM
japspecb7's Avatar
could be the breather chamber/oil catch can on the back of the block. Theres a little seal that goes bad after a while in there check it out.
blacktibby07
May 14, 2011 11:12 AM
tigasin
Nov 14, 2008 11:58 PM
gsr.tuner
Nov 13, 2008 04:50 PM
fabe85
Nov 27, 2004 11:30 PM
untitled
Aug 13, 2003 10:37 AM
