NEED HELP - Rack & Pinion - Question!?
Old May 12, 2008 | 05:05 PM
mackadocious's Avatar
* B A N N E D *
Default NEED HELP - Rack & Pinion - Question!?
Im buying my friend car its a Ef9 and its Drop he told me the Rack And Pinion Eats up the tire...and said if i leave it i have to change the tire every 2 to 3 months ..its just the front left side tire ...the right side and the rest of the tires are ok.... i was wondering why does it eats the tire and what i have to buy or replace it with to make it stop wasting the tires...is it too drop or iunoe ... need help thanks
Old May 12, 2008 | 08:02 PM
90blackcrx's Avatar
Default Re: NEED HELP - Rack & Pinion - Question!? (mackadocious)
Have the camber checked first, make sure the tow is not miss adjusted.
Old May 12, 2008 | 09:10 PM
EF'n C5's Avatar
go get an aligment. there is no (accurate) way to check it yourself. don't even mess around with it. alignments are cheap and they save you alot of money in the long run.
post your specs afterwards and i'll tell you if anything is bent, and what you can do about it.
Old May 12, 2008 | 09:19 PM
* B A N N E D *
Default Re: NEED HELP - Rack & Pinion - Question!? (EF'n C5)
im get that align ..and see how everything works ...
should i get a camber kit and let my friend check it
or find some one with experience to check it ...
Old May 12, 2008 | 09:46 PM
bobjohnson's Avatar
Unless your friend works at an alignment shop... no.
You cant eyeball an alignment, and anyone who says they can is an idiot.
Old May 12, 2008 | 10:26 PM
* B A N N E D *
Default Re: NEED HELP - Rack & Pinion - Question!? (bobjohnson)
alright thanks
Old May 14, 2008 | 07:32 PM
* B A N N E D *
Default Re: NEED HELP - Rack & Pinion - Question!? (90blackcrx)
other than the tires can anything else happen to the car with out a camber kit ?
EJ1JDM
16
Jun 21, 2011 04:06 PM
zcmotor
53
May 24, 2008 02:04 AM
alex_s817
Mar 25, 2006 09:43 AM
sf89lx
Jan 25, 2006 04:23 PM
4DRPIMPIN
Suspension & Brakes
28
Feb 24, 2005 09:11 AM
