Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Knocking in front Suspension
Old May 12, 2008 | 04:37 PM
GriFFIthS's Avatar
Default Knocking in front Suspension
Ok i have a stock suspension and its knocking in the front when i hit bumps, sounds alot like the struts are on their way out, i've had the wheel off had a look up around and it doesnt seem like the strut is hurt at all, with the tire on theres virtually no play in the tire so i'm starting to rule out the strut, anyone have any idea what could be causing this? possible bad bushing maybe?
Old May 12, 2008 | 04:41 PM
01blackcivic's Avatar
Default Re: Knocking in front Suspension (GriFFIthS)
had the same problem when i first got my car. Took it right back to the dealer to find out the bump stop on the front right was missing. Every time i hit a bump it would slam loudly. hope this helps
Old May 12, 2008 | 04:45 PM
GriFFIthS's Avatar
its not a loud sound, but sounds almost exactly like a bad strut, but the strut seems fine, i'm not all that up on the inner workings of a suspension or the parts themselves but theres an arm behind the wheel berring and continues to the front of the car at the end theres a bushing, the rubber on the top of that bushing has a few cracks in it, obviously that seems to be on its way out too but could that be whats causeing the noise instead of the strut?
Old May 12, 2008 | 06:11 PM
Dillon91Teg's Avatar
Default Re: (GriFFIthS)
i have the same problem on my 2001. even after i changed out the struts its still there. so i decided i'm gunna get an alignment maybe that will work for u too i hope it does for me.
Old May 12, 2008 | 06:16 PM
GriFFIthS's Avatar
yea i have an appointment tomorrow afternoon for an alignment, just had my winter tires/rims off today and notice some slight wear along in the inside of the front tires, this is the first time i had my Blades on my car and i have new tires on those rims that i dont want worn early, hopefully an alignment will fix the knock, as long as its not a danger to myself or anyone else on the road i'll just deal with the noise untill i can go get it fixed if it is someting else.
Old May 12, 2008 | 07:55 PM
recaroem2's Avatar
might be the bushing
Old May 16, 2008 | 09:28 AM
GriFFIthS's Avatar
So it turns out the Passenger side Ball Joint is starting to give out, and both front struts are starting to leak out, $350 in parts and 3 hours labour later and no more knock.
Old May 16, 2008 | 09:32 AM
Harlowe's Avatar
Function>Fashion
Look at the bushings, and make sure your middle strut bolt is tight. Mine was loose and was making a noise.
Old May 16, 2008 | 09:41 AM
GriFFIthS's Avatar
bushings are fine for now, the strut isnt bad, but its leaking now and once it starts it wont stop, so they're gonna be replaced, and the ball joint is starting to get bad, but its only gonna get worse, gonna have all this work done next wednesday
Old May 20, 2008 | 05:56 AM
jedi03's Avatar
as another point of reference even though see prob was fixed, had loose strut to camber plate bolts caused loud knocking on mine...tightened to approxl 150 ft/lbs (recommended by manual is 124 i think) an fixed for me
Reaccion
Honda Civic (2006 - 2015)
Nov 6, 2012 07:22 PM
HondaHeddie
Mar 27, 2009 10:08 AM
reeder321
Nov 26, 2008 06:05 PM
SiR99
Jul 30, 2006 01:39 PM
brbHPR
Aug 26, 2003 08:44 PM
