Trunk Lining Removal How To?
Hello.
I'm planning to switch the XM hardware out of my '08 Si and replace with Sirius equipment so I can use the stock hardware. Anyone know how to go about removing the trunk lining? I don't want to miss anything and end up ruining it.
Thanks.
Thanks.
You should see clips all over inside your trunk. They look like a black plastic flatblade screw. Take a flatblade screwdriver and unscrew the screw and that will loosen the clip. Pull the entire clip out and put it somewhere it won't get lost. Do this with all of the clips. I'm not sure how many there are, but it won't take you more than 2 minutes to remove them all. When they are all removed, you should be able to fold the carpet up and have full access to what is under there. Good luck!
