fuel pressure question
i just tested the fuel pressure on my 91 integra b18a
With the fuel pressure regulator connected and engine running 38 psi,
With engine running and the pressure regulator vacuum hose disconnected it was at 42 psi. Are these acceptable pressures? I just replaced the fuel filter!
THIS SHOULD HELP YA OUT
With vacuum attached- (1990 26 to 32 psi) (1991 28 to 35 psi) (1992-93 32 to39 psi) and gsr (B17 39 to 46 psi)
With vacuum disconnected- (1990 35 to 41 psi) (1991 37 to 41 psi) (1992-93 41 to 48 psi) and gsr (B17 48 to 56 psi)
thanks so much, i thought it seemed low but it wasnt i guess, its definatly low compared to an accord, used a 99 service manual to test the pressure.
spooledhonda
Jan 3, 2006 03:23 PM
