Top line oil pump any good??
Old May 12, 2008 | 12:09 PM
eg6madness's Avatar
Default Top line oil pump any good??
Are their oil pumps any good. Want to replace the one on my OBD 1 GSR and came across these, so just want to know you guys opinion .
Old May 12, 2008 | 02:29 PM
DonF's Avatar
Default Re: Top line oil pump any good?? (eg6madness)
How much chearper is it then OEM? That plus 20% is how much quicker it will fail before the correct one. Just rule of thumb.
Old May 12, 2008 | 02:43 PM
all-mtr-teg's Avatar
Default Re: Top line oil pump any good?? (DonF)
Does that same rule generally apply for say bearings or rings?
Old May 12, 2008 | 02:51 PM
DonF's Avatar
Default Re: Top line oil pump any good?? (all-mtr-teg)
Generally from Topline or Bernie's parts, YES. From ACL, Clevite, NPR, Wiseco, Speed-Pro, Hastings, Gates, Goodyear, NO.
Old May 12, 2008 | 02:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Generally from Topline or Bernie's parts, YES. From ACL, Clevite, NPR, Wiseco, Speed-Pro, Hastings, Gates, Goodyear, NO.</TD></TR></TABLE>
Good to know, been using ACL, Clevite bearings and Hasting, NPR rings
What about Mahle parts?
Old May 12, 2008 | 04:02 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">
What about Mahle parts?</TD></TR></TABLE> Well I do not know if they are good enough for H-T guys, but they seem to work for Formula 1 guys, or Porsche, Mercedes, Audi, and Ferrari. Probably not expensive enough on E-Bay.
Old May 12, 2008 | 04:39 PM
00MRSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote"> Well I do not know if they are good enough for H-T guys, but they seem to work for Formula 1 guys, or Porsche, Mercedes, Audi, and Ferrari. Probably not expensive enough on E-Bay.</TD></TR></TABLE>
LOL
Old May 12, 2008 | 05:05 PM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote"> Well I do not know if they are good enough for H-T guys, but they seem to work for Formula 1 guys, or Porsche, Mercedes, Audi, and Ferrari. Probably not expensive enough on E-Bay.</TD></TR></TABLE> Mahle is just starting to get on board with import guys and I'm thankful to see it
Old May 12, 2008 | 07:38 PM
Yeah, the local machine shop stocks mahle and clevite, he also recommended total seal rings for my build, what do you think about those rings?
Old May 12, 2008 | 08:08 PM
eg6madness's Avatar
the topline oil pump is $90 and the typeR is $117.
What has to be modified if i install a Type R oil pump on my OBD 1 GSR ?
Old May 12, 2008 | 08:16 PM
OBD1 lower timing belt cover.
Old May 13, 2008 | 04:09 AM
Furyof4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6madness &raquo;</TD></TR><TR><TD CLASS="quote">the topline oil pump is $90 and the typeR is $117.
What has to be modified if i install a Type R oil pump on my OBD 1 GSR ?</TD></TR></TABLE>
Hondapartscheap.com
$90.79 oem
No reason to buy topline.
http://www.hondapartscheap.com...ity=0
Old May 13, 2008 | 07:38 AM
Default Re: Top line oil pump any good?? (Furyof4)
This ones cheaper after shipping and handling charges
http://www.hondapartsunlimited...t.jsp
To the OP, don't fall for the Type R hype, its only a GSR oil pump look at the part number.
Old May 14, 2008 | 10:51 AM
soulpwr's Avatar
Well what about topline pistons then?
Old May 14, 2008 | 11:18 AM
Rocket's Avatar
Default Re: Top line oil pump any good?? (soulpwr)
Mahle has traditionally been the choice of various car makers for their higher end models such as GM using Mahle for Corvettes and Chrysler using Mahle pistons for the Shelby turbo charged models.
Maybe someone can step up and get pistons from Mahle for honda and then sling on ebay for $5 gross profit and provide dyno-advertising sheets showing 30-40whp gains from just piston swap . That would da bomb, off da hizzay, fo shizzay, popo-zao :kfed shot-caller, big-baller looking character wear XXXL "shorts" and a Mack Truck cap:
Old May 14, 2008 | 11:23 AM
PuroMotor's Avatar
Default Re: Top line oil pump any good?? (Master of the Universe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe &raquo;</TD></TR><TR><TD CLASS="quote"> That would da bomb, off da hizzay, fo shizzay, popo-zao :kfed shot-caller, big-baller looking character wear XXXL "shorts" and a Mack Truck cap:</TD></TR></TABLE>
hahahahaha
k24killer
May 23, 2007 08:14 AM
ST4TUS
13
Dec 20, 2006 02:18 AM
si95
Nov 30, 2006 04:06 AM
Aiden2002
Mar 4, 2006 11:40 PM
soon2b
Sep 22, 2005 07:11 PM
