OBD2B P73 Type R ECU in a 99 Civic SI OBD2B, wont start, any ideas?
Old May 12, 2008 | 09:53 AM
99B19CEK's Avatar
Default OBD2B P73 Type R ECU in a 99 Civic SI OBD2B, wont start, any ideas?
Anyone have any ideas why this ECU will not start my car. There is no response from the main relay or the fuel pump. The Check engine light comes on immediately.
Are the Pin outs different, or do you need to switch some of them around?
Old May 12, 2008 | 10:35 AM
Relic1's Avatar
OBD2B P73 has immobilizer.
You're not going anywhere without getting it programmed, and having the antenna/key setup installed.
Old May 12, 2008 | 10:46 AM
99B19CEK's Avatar
Default Re: (Relic1)
Sorry, its a JDM P73 ECU, this doesn;t have the immobilizer unit.
Any ideas?
Thanks.
Old May 12, 2008 | 10:56 AM
j_scobar's Avatar
Default Re: (99B19CEK)
Check what Code the ECU is giving and let's go from there.
As far as the pins are concerned, they sould all be the same.
Old May 12, 2008 | 11:11 AM
Relic1's Avatar
JDM P73s are ALL OBD2a.
https://honda-tech.com/zerothread?id=2067011
JDM ECUs will never pass emissions in cali either. they run OBD1 code in an OBD2 case, they have no way to communicate to the scan tool.
the questions is, what do you really have...
check the part number on the side of the ECU and the post I linked to.
Old May 12, 2008 | 11:20 AM
99B19CEK's Avatar
http://cgi.ebay.com/ebaymotors...&rd=1
here is the add that I bought it from
I will check the code and post it.
So definitely there is no OBD2B JDM ITR ECU's, only OBD2B PCT's right?
I looked at the ECU and opened it, and there is no immobilizer board also. Shouldn't there be one?
Old May 12, 2008 | 12:13 PM
serio_ENDLESS's Avatar
from the numbers i read it has a immobilizer and you have to repin the fuel pump relay which it will not let your car start
the pins you have to switch is a16 to a15
and aswell the immobilizer must be removed
Old May 12, 2008 | 12:36 PM
99B19CEK's Avatar
Default Re: (serio_ENDLESS)
Thank you all for the help, as the ad I showed you all from eBay shows a "JDM" P73 I am going to return it, I don't want to deal with the headache of re-pinning and dealing with the immobilizer.
This seller should not have put JDM in the title because it was confusing.
I am used to the OBD1 ecu stuff and never dealt with the newer crap.
Old May 12, 2008 | 12:43 PM
Relic1's Avatar
37820-P73-A04 = 00-01 USDM ITR
does have Immob, if not present then it was removed. (having it bypassed and removed causes the CEL to be on, but the car will run)
If you are looking for a JDM P73, search for a 37820-P73-003, 013 or 023.
again check the thread that I linked to above, it lists all the P73s that I could find and their origins.
Old May 12, 2008 | 01:35 PM
99B19CEK's Avatar
Default Re: OBD2B P73 Type R ECU in a 99 Civic SI OBD2B, wont start, any ideas? (99B19CEK)
Thanks, I will probably buy a JDM PCT ECU since the seller is going to refund the money for this one.
Old May 12, 2008 | 02:36 PM
Relic1's Avatar
PCT/P73, do you have a B16 or B18?
Hopefully you don't think that the two ECUs are swapable. There are fuel and ignition differences between the two.
Old May 13, 2008 | 04:29 AM
j_scobar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">PCT/P73, do you have a B16 or B18?
Hopefully you don't think that the two ECUs are swapable. There are fuel and ignition differences between the two.</TD></TR></TABLE>
Probably a b16
Old May 13, 2008 | 02:44 PM
99B19CEK's Avatar
If this damn site allowed more than 5 postings a day. Forgot my old HT ID and cannot find it.
I totally forgot about the fuel curve for the 1.6 in the PCT. I have a 1.8 stroked to a 1.9. I am going to use a chipped P28 instead. This is just for daily driving to work and back, that is why I needed something more on the stock curve for fuel delivery.
I will just use the Apexi VAFC to adjust the fuel curve to 14:7 with the P28.
Old May 13, 2008 | 03:27 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B19CEK &raquo;</TD></TR><TR><TD CLASS="quote">If this damn site allowed more than 5 postings a day. Forgot my old HT ID and cannot find it.
I will just use the Apexi VAFC to adjust the fuel curve to 14:7 with the P28.</TD></TR></TABLE>
Depending on which chip of course... IMO you'd better off with the P73 and pushing in slightly more fuel via increasing the FPR 5-7psi.
random chip and VAFC... god knows what the ignition settings are going to be.
(VAFC fakes the ECU into changing fuel settings, this also adjusts the ignition settings) Hence why most people with hondas do not use VAFCs anymore. There are so much better alternatives out there. (Crome, eCtune, hondata, etc)
Old Dec 3, 2009 | 09:35 PM
bigwalt707's Avatar
Icon3 Re: OBD2B P73 Type R ECU in a 99 Civic SI OBD2B, wont start, any ideas?
ok so sorry to add more but i did a swap in my 97 ex with the b16a2..i have no check engine and the car was running fine till the other day i needed to change the ivap and did a tune up now the car wont start even put old parts on still wont start....cracks over and check engine light comes one rapid flashes like rave light and my reader cant communicate with the ecu when this is going on, once it does it for 30sc or so it stops and fuel pump kicks back on and i try crank it over agen and it repeats i need help...and there is no check engine light every thing reads fine...
Chriseh9
Dec 10, 2018 06:49 PM
crookson speed
Feb 19, 2014 01:32 PM
91civicEX
Dec 12, 2003 11:44 AM
Red_Si
Apr 29, 2003 10:27 AM
EE9
Jan 2, 2003 06:04 AM
