So I had a CEL, got it checked: every cylinder misfiring (10 codes)
Old May 12, 2008 | 06:19 AM
WhiteOnRice's Avatar
Default So I had a CEL, got it checked: every cylinder misfiring (10 codes)
Last weekend I swapped an a2 into my EP. The only problem I had was an IACV CEL. About 3 days after the swap was complete the idle "cured" itself. The CEL remained on so I reset the ECU. The idle was good, no CELs so I drove it to work (friday).
Immediately after starting the car to drive home I get another CEL. I get off work at 12:30am so I couldn't do anything about it. I filled my tank at Shell and went home. Sunday I went to Autozone to get "the" CEL checked and it's throwing 10 codes: 2 for each cylinder misfiring and 2 "random cylinder misfires." The autozone guy said the usual: "when did you replace the plugs last?" But I know it's something more large scale than that.
The car has a major loss of power (feels like the k20a3) but idles good and the "misfires" aren't audible.
Any ideas guys?
Old May 12, 2008 | 09:20 AM
RIZOBIZERT's Avatar
Default Re: So I had a CEL, got it checked: every cylinder misfiring (WhiteOnRice)
Running 93 octane? Just a guess since that is the only thing you've done since the swap.
Old May 12, 2008 | 11:08 AM
Yep, I have been using V-Power 2 tanks before the swap. That's what I thought it would be but shouldn't be. I also got a different muffler welded on but it's a wide open series magnaflow so I doubt it's causing the problem.
Old May 12, 2008 | 02:39 PM
RIZOBIZERT's Avatar
Default Re: (WhiteOnRice)
Have you done any further investigating? Have you pulled the plugs? Condition of the plugs? Don't just assume that they are good.
Old May 12, 2008 | 03:00 PM
JCL's Avatar
JCL
plugs and coil packs? ...
Old May 12, 2008 | 06:52 PM
Yeah I checked the plugs and 1 was bad. I replaced it with the best one from my a3. I'll be getting 4 new plugs soon. The coil packs weren't melted or anything. How do I know they are good?
Old May 13, 2008 | 03:18 AM
RIZOBIZERT's Avatar
I'm not sure how you check the coil packs. I have the service manual and it was less than helpful. I would like to know as well. You can always ground the plug out of the head and visually check for spark to see if you have discrepancies between plugs/coil packs.
Old May 13, 2008 | 04:31 AM
blueshark123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I checked the plugs and 1 was bad. I replaced it with the best one from my a3. I'll be getting 4 new plugs soon. The coil packs weren't melted or anything. How do I know they are good?</TD></TR></TABLE>
Do you have kpro? Also get new plugs NGK heat range 7 asap. The plugs that were in your a3 are range 6 and will heat up causing misfiring or detonation.
Old May 13, 2008 | 12:43 PM
No kpro, it's running off the PRB ecu.
I'm only using 1 a3 plug. Would any auto parts store have those plugs? I can't find them on ebay.
Old May 15, 2008 | 07:29 AM
RIZOBIZERT's Avatar
Any major chain will have the necessary plugs. Good luck and let us know.
Old May 15, 2008 | 08:28 AM
I found out one cylinder is running rich. Here's my thread: https://honda-tech.com/zerothread/2300254
Please help if you are knowledgeable in the area.
PhoenixDownVII
Jun 7, 2009 07:03 PM
swappedcx
Feb 16, 2006 10:38 PM
slackeR1366
May 6, 2002 12:48 PM
