help on d16 mini swap
hi, i have and ef that need help on a mini swap... my problem is that i have a d16a block but no head, manifold and no dizzy but i have a d16y head, manifold, and an lx dizzy, and all the sensor.. do i need to get all the obd1 plugs? are all the sensors on the d16y work with my d16a ecu? please help.
Then you will need the dizzy from the d16a6, it bolts right up to the Y8 so I guess it will do the same for the Y7. You'll need obd0 injectors and resistor box, and pm6 ecu from the d16a6. The sensors off the intake mani should work but you will need to extend a couple wires. Check the FAQ's for the mini me write up for all this info (really should have been your first move).
go obd1 its better because one wire tech is a pain to program and set the fuel
do thiss if ur useing a obd0 u need to use a si dizzy but the fireing order will be off by one position so just move the plugs over oneand ull be fine if ur going obd1 find a non vtec dizzy off a d15b7 eney non vtec will work dx works best for 92 dizzys that dizzy is a direct match to a y8 dizzy use the 92 dx one then u need to wire up some parts the problem will be with the manifold if u use a obd1 mani u will have some trouble with coolent lines if u use a obd0 one u should be oke the problem is that the obd1 one needs a extra coolent pick up for the throttle body if u want i am willing to help u with a retro fit i know every posible combo lol i also got some parts as well as ecus if u need some info just pm me ill help u out
oldschoollove
14
Oct 1, 2009 03:01 AM
eumoria
Apr 27, 2005 09:57 AM
