Clutch feels loose?
Old May 11, 2008 | 09:28 PM
seanyboy's Avatar
Default Clutch feels loose?
everyone who drives a stick on a honda knows that the clutches (oem for that matter) are really sensitive. well last night my clutch was fine when i parked it. i put my autolock on and everything seemed fine.
then this morning on my way to work.. i'm about to leave my house... then i stall (first time in a year). i come to realize that the engagement point for my clutch seems a little later. like my clutch for the first two inches you push it seems like it has no resistance at all.
i got a new clutch about two months ago and have put 1500 miles on it since.
my brother says its just that the clutch has been worn in properly. i feel that the change in engagement points was too dramatic of a change.
anyone have insight?
Old May 12, 2008 | 09:11 AM
seanyboy's Avatar
Default Re: Clutch feels loose? (seanyboy)
bump
Old May 12, 2008 | 09:52 AM
love4dirt's Avatar
assuming it is a hydro clutch, check your fluid level if your low on fluid fill it up with some dot 3 bleed out the air in the line and start looking for a leak. by later you mean you have to press the clutch pedal more right?
Old May 12, 2008 | 11:30 AM
v8 integra's Avatar
Default Re: Clutch feels loose? (love4dirt)
check ur firewall where ur master cylinder is for leaks(if the firewall is wet)..and also check the clutch slave cyclinder...pull the rubber boot back and see if theirs any fluid...
Old May 12, 2008 | 10:01 PM
seanyboy's Avatar
just checked it... theres not fluid in the clutch cylinder. ill fill it up with brake fluid. is there any reason to why my fluid is low other than a leak?
Modified by seanyboy at 11:11 PM 5/12/2008
Leslie.
May 5, 2017 09:09 PM
fab
Nov 16, 2004 06:10 PM
SuperRice
Jun 6, 2003 11:24 AM
Buckshot
Nov 17, 2002 08:43 PM
Buckshot
Sep 11, 2002 05:05 AM
