cant tell if its a rod knock im lost...
Old May 11, 2008 | 09:22 PM
preludeboybmw's Avatar
Default cant tell if its a rod knock im lost...
the noise is not constant, everyone tells me its not a rod knock sounds like its coming bewtween head and block to me under the vavle cover...i check everything i can with out taking motor apart , the timing is right no bogs nothing is loose , new clutch and tune up , i just swaped this motor first start up its been doing it ..idk wat else i can do before i take motor apart
Old May 11, 2008 | 09:40 PM
pkolaboy's Avatar
Default Re: cant tell if its a rod knock im lost... (preludeboybmw)
its more likely not a rod knock if its not knocking constantly...when i had my rod knock it did it constantly... i would just check your spark plugs and everything like that... also when your rod knocks, you can not tell where its coming from because its loud....try posting a video of it..
Old May 11, 2008 | 09:46 PM
Hawkze_2.3's Avatar
Is it an obvious knock sound or is it more of a tick sound?
Old May 11, 2008 | 09:47 PM
no1knows908's Avatar
Default Re: cant tell if its a rod knock im lost... (pkolaboy)
Almost 100% sure you just need a valve lash adjustment. If it's coming from right under the VC then that's most likely it. A valve adjustment should be part of your major tune-up procedures.
Old May 11, 2008 | 09:55 PM
idk its not like a tap like a loud idk like something is loose or not tight all the way, when u rev it up is when u hear it clear after 1500 or soo but its not too loud at idle u can bearley hear it , ill try to post a video
Old May 11, 2008 | 10:11 PM
Hawkze_2.3's Avatar
Default Re: (preludeboybmw)
Yeah I agree it's probably loose valves. Do a valve adjustment and it should get better
Old May 11, 2008 | 10:42 PM
well its constant when u leave it at certain rpm , tomarrow ima see if it needs to be adjusted
Old May 11, 2008 | 10:45 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeboybmw &raquo;</TD></TR><TR><TD CLASS="quote">well its constant when u leave it at certain rpm , tomarrow ima see if it needs to be adjusted</TD></TR></TABLE>
How are you going to do that? You have feeler gauges and a Helms manual?
Old May 11, 2008 | 10:59 PM
Mykizism's Avatar
its most likely rod knock, if you cant hear it at idle.. but hear it while driving..
does the sound change when the throttle % is changed? ie no noise at 0% throttle input.. then you can hear the sound around 30-50% throttle
also does it sound like as if you have a exhaust leak? but only sometimes.??
if so.. its most likely rod knock.. rod knock also means ur bearing is gone..
which means you`ll need to rebuild.. and get a new crank..
do not regrind a stock crank.. the surface are heat treated to make it hardned..
Old May 11, 2008 | 11:01 PM
yeah i got the manual lol , and tomarrow ima have my buddy bring over the feeler guage
Old May 12, 2008 | 09:27 AM
well no one knows wtf it is , he said maybe oil pump he dont know nither , heres some videos i found this wat it almost sounds like
http://youtube.com/watch?v=lNM...lated
http://youtube.com/watch?v=2P7...lated
Old May 12, 2008 | 09:32 AM
Mykizism's Avatar
thats sounds like rod knock to me man
Old May 12, 2008 | 09:56 AM
98vtec's Avatar
moderator emeritus
Default Re: (Mykizism)
sounds like piston slap or rod knock.
and why are you posting nissan related stuff in the prelude forum?
Old May 12, 2008 | 10:51 AM
Hawkze_2.3's Avatar
Yeah, those videos sound worse than valves ticking for sure...
Old May 12, 2008 | 04:33 PM
im showqing you guy wat noise it makes in the videos...
Old May 12, 2008 | 10:43 PM
pkolaboy's Avatar
lol wow... if your car makes the sound like that nissan does than thats a big prob....
Old May 13, 2008 | 10:36 AM
94vtecmn's Avatar
Default Re: (pkolaboy)
I can't open the video to hear it now, but what you are describing may be the LMA's making noise. If its up top on the motor, could be it.
Old May 14, 2008 | 09:35 AM
93sivtec's Avatar
If it sounds like its coming from inside the valve cover.....its valve lash.And just so u know u can feel a rod knock in the gas pedal,and its constant,not periodicly.
Old May 16, 2008 | 12:32 AM
BB1LOViN's Avatar
Default Re: (93sivtec)
not sure if it applies for you but my h22a1 used to make a knocking sound like that only around 2500rpms. it turned out to be my timing belt tensioner.
Old May 16, 2008 | 04:44 PM
Sampsonite987's Avatar
Default Re: (BB1LOViN)
I think I know what noise you are talking about. My H22 makes a similar noise when it is cold and at low rpm. I am due for a valve adustment and I will see if that clears up my problem.
Old Mar 10, 2009 | 03:05 PM
stanleybb50's Avatar
Hey did your H22 make that noise only when the car was hot? And/or only when driving under a very light load?
Old Mar 10, 2009 | 03:37 PM
turnofftheradio's Avatar
are you in a 5th gen? if yes check your timing belt tensioner. mine made a slappy-knocky noise when it failed at 30k. was worse around 1200rpm then faded away with an increase of rpm you could hear it at idle though.
be careful of the auto tensioner. it can cause a lot of damage if it fails.
Old Mar 10, 2009 | 05:05 PM
Its actually a 6th gen...
I dunno.. doesnt quite sound like the noise you described i guess..
Old Mar 10, 2009 | 05:17 PM
I am confused by 6th gen... but if you have an h22a4 from usdm 97-01 I would really suggest inspecting your tensioner if it is an auto (hydraulic) type. the way you describe it to me sounds similar enough to make me suspicious. the auto tensioner is a common failure.
Old Mar 11, 2009 | 05:15 PM
Hey, actually - if you don't mind... Could you check out this post that was made on Driveaccord.net or whatever.
http://www.driveaccord.net/forums/sh...ad.php?t=15602
My noise sounds EXACTLY like the poster's noise with the exact same symptoms and everything... I also made a post there...
If you got the time, check it out and let me know your thoughts - (if you dont mind!)
The guy who made the post doesnt seem to use the website at all anymore, but at the time, he didnt know exactly what the noise was.
(just to add... Its been makin the noise since I got it like 20K miles ago... and hasnt really gotten any worse...) but it really does sound bad and only does it when hot and under light load...
