crack in the block fixable or not
Old May 11, 2008 | 09:16 PM
1993gsrcivic's Avatar
Default crack in the block fixable or not
on my gsr block where the oil pressure sensor goes is cracked well what can i do about that?
is it possible to close that hole in the block and put the sensor on like a sandwich plate
or is there a way i can still put the sensor there and use something to seal it?
help me!!!!!!!!!
Modified by 1993gsrcivic at 11:46 PM 5/14/2008
Old May 11, 2008 | 10:39 PM
all-mtr-teg's Avatar
Default Re: crack in the block fixable or not (1993gsrcivic)
Pics aren't available, worse case scenerio, have it welded and retapped.
Old May 12, 2008 | 08:14 AM
Default Re: crack in the block fixable or not (all-mtr-teg)
bump any other ideas
Old May 12, 2008 | 09:08 AM
satitus's Avatar
I see you are in Baltimore, MD. Give Burtonsville Performance Center a call and ask what they can do. They work magic with blocks.
Old May 12, 2008 | 12:02 PM
Fat Chick Magnet's Avatar
Pictures don't work we can't help you out.
Old May 12, 2008 | 12:13 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993gsrcivic &raquo;</TD></TR><TR><TD CLASS="quote">bump any other ideas</TD></TR></TABLE>
bump yeah I have one. Fix the pics.
Old May 12, 2008 | 10:35 PM
Default Re: crack in the block fixable or not (Combustion Contraption)
i can see the pictures fine so i dont know whats wrong with your computer
Old May 12, 2008 | 10:55 PM
gsrob's Avatar
No one can see the pictures to even assess the damage.
Old May 12, 2008 | 10:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993gsrcivic &raquo;</TD></TR><TR><TD CLASS="quote">i can see the pictures fine so i dont know whats wrong with your computer</TD></TR></TABLE>
This explains why you've been so successful so far.
Old May 12, 2008 | 11:23 PM
make lifer easier.
http://www.tinypic.com
Old May 13, 2008 | 08:04 AM
Default Re: (Fat Chick Magnet)
pics are fixed
Old May 13, 2008 | 09:42 AM
FST GSR 1's Avatar
I may be new to posting on here, but those pictures are horrible.
If you want to fix it right, weld it up. Grind off the remaining as flat as possible, get a piece of aluminum stock close to the diameter of the boss, turn a .125" chamfer on one end and weld it. It could be tapped before welding.
Modified by FST GSR 1 at 10:59 AM 5/13/2008
Old May 13, 2008 | 11:03 PM
prettylew's Avatar
thats your knock sensor first of all. not your oil pressure.
so sealing it isnt a problem because its just a threaded piece on your block like a bolt hole.
weld the piece back on. and rethread with a 12x1.25 tap.
and next time dont tighten it so much. not everything needs to be "lug nut" tight
Old May 14, 2008 | 03:15 AM
Rocket's Avatar
Default Re: (prettylew)
LOL.
Why put it back on at all?
Tell me one good reason other than you want o use a un-modified P72 ecu and pass smog.
Old May 14, 2008 | 06:50 AM
prettylew's Avatar
Default Re: (Master of the Universe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe &raquo;</TD></TR><TR><TD CLASS="quote">LOL.
Tell me one good reason other than you want o use a un-modified P72 ecu and pass smog.</TD></TR></TABLE>
true, i just assumed he's using a stock ECU. and if he is, he needs it. if your running a chipped ECU then simply throw it in the trash lol
Old May 14, 2008 | 06:56 AM
sorry you dont know a motor its the oil pressure its a whole that goes through the block to the oil passage the knock sensor is fine
Old May 14, 2008 | 07:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prettylew &raquo;</TD></TR><TR><TD CLASS="quote">thats your knock sensor first of all. not your oil pressure.
and next time dont tighten it so much. not everything needs to be "lug nut" tight</TD></TR></TABLE>
Not a knock sensor, that's an oil pressure sensor
Old May 14, 2008 | 12:27 PM
prettylew's Avatar
Default Re: (1993gsrcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993gsrcivic &raquo;</TD></TR><TR><TD CLASS="quote">sorry you dont know a motor its the oil pressure its a whole that goes through the block to the oil passage the knock sensor is fine </TD></TR></TABLE>
sorry dick. just tryin to help. maybe if you learned how to take good pics we could see better.
but to me that pic of the block looks like its at the TOP of the motor, right near the deck, and it looks like its right above the coolant pipe that runs across the back of the motor. which is where the knock sensor is.
Old May 14, 2008 | 12:35 PM
I only clicked on the first pic. Looks like a knock sensor boss to me.
Old May 14, 2008 | 12:39 PM
prettylew's Avatar
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">I only clicked on the first pic. Looks like a knock sensor boss to me.</TD></TR></TABLE>
thank you!!!!!! lol. glad im not the only one.
Old May 14, 2008 | 04:11 PM
well the second pic is the sensor so read everything or look at all the pics first before you comment something
and now back to the original question what can i do to fix this
Old May 14, 2008 | 06:00 PM
GhostAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">have it welded and retapped.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satitus &raquo;</TD></TR><TR><TD CLASS="quote">Give Burtonsville Performance Center a call and ask what they can do. They work magic with blocks.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FST GSR 1 &raquo;</TD></TR><TR><TD CLASS="quote">If you want to fix it right, weld it up. Grind off the remaining as flat as possible, get a piece of aluminum stock close to the diameter of the boss, turn a .125" chamfer on one end and weld it. It could be tapped before welding.</TD></TR></TABLE>
What answer are you looking for? I'm guessing none of these are the answer your looking for. I bet Your looking for something cheap that you can do yourself. If that's the case you could learn how to aluminum weld and DIY. Or you could try crazzy glue or a 2 part epoxy aka JB weld. They both work about the same around heat and oil. Not all that dependable.
Old May 14, 2008 | 06:37 PM
BearsEK-KMSU's Avatar
Default Re: (GhostAccord)
If you haven't heard already that sensor isn't supposed to be in that hole anyways. just leave it empty you will never need it. Oh wait people tune off the b series knock sensor right?
Old May 14, 2008 | 06:39 PM
prettylew's Avatar
Default Re: (BearsEK-KMSU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BearsEK-KMSU &raquo;</TD></TR><TR><TD CLASS="quote">If you haven't heard already that sensor isn't supposed to be in that hole anyways. just leave it empty you will never need it. Oh wait people tune off the b series knock sensor right? </TD></TR></TABLE>
yet ANOTHER vote for knock sensor. we need better pics. thats 3 people that say what you took a pic of is the knock sensor boss.
is that broken piece near the head? or near the oil pan?
Old May 14, 2008 | 07:43 PM
ok now look at the pic the knock sensor is on the left the the oil pressure thing is on the right
Modified by 1993gsrcivic at 12:41 AM 5/15/2008
