Prodject 85x95 last attempt at a big B before building a big K. Kingmotorsports
Old May 11, 2008 | 08:56 PM
BearsEK-KMSU's Avatar
Default Prodject 85x95 last attempt at a big B before building a big K. Kingmotorsports
Ok most of you have have seen my old drag car enigne (84.5x89) 275 WHP 173 WTQ. Well two years @10,000 rpm and multiple 11.3 passes with a best of 11.28 @120 its time to go bigger with a final attempt to go tens before building a big K. The only way other than working on the chassis more is a bigger engine with more (get me down the strip faster) torque. So here starts the build thread it won't be a year prodject the car has to race in two weeks so here we go!!!!!
The specs,
Crower 95mm stroker crank
ERL superdeck 2 tall deck! (Thanks Sean)
Wiseco custom pistons cc'd 3.94 dome displacement
Eagle 5.967 Heavy H-beams re-tanged for type R bearings and drilled oil holes
(hey they were cheap the engine needs to prove itself first)
Pure Tuning ported b16 head from old engine (flow master Aaron)
(new Tucker oversized valve seats new bronze guides)
Supertech valves cryoed
Skunk2 Pro-series valves springs cryoed
Crower cro-moly retainers cryoed
Ferrera valve keepers cryoed and guides
Skunk2 Pro-3's
Skunk2 Pro series cam gears
SMSP B20 vtec header
Hondata s300
E85 fuel
Precision 650cc injectors
C/R should be around 14.6:1
The pics
More pics as I get parts assembled. Stay tuned
Modified by BearsEK-KMSU at 10:46 AM 5/12/2008
Modified by BearsEK-KMSU at 9:12 AM 5/15/2008
Old May 11, 2008 | 09:22 PM
bjones's Avatar
Default Re: Prodject 85x95 last attempt at a big B before building a big K. Kingmotorsports (BearsEK-KMSU)
wow... another sick build coming from you guys
Old May 11, 2008 | 09:31 PM
00b18b's Avatar
you never cease to amaze me...another awesome build. Don't forget dyno numbers and vids!!!!!
Old May 12, 2008 | 05:13 AM
mar778c's Avatar
Community Builder
Community Influencer
Very nice project.
One question, you seem to have some large gaps between the sleeves at the deck. Is this normal?
Old May 12, 2008 | 05:17 AM
Default Re: Prodject 85x95 last attempt at a big B before building a big K. Kingmotorsports (mar778c)
Every block is a little different, I have seen many way worse and never matter much.
Old May 12, 2008 | 05:38 AM
b20beast978's Avatar
how much whp are you looking to make? 300+??
Old May 12, 2008 | 05:51 AM
Default Re: (b20beast978)
Honestly, i told myself I would be happy with 295 whp. 300 would be great but i am not sure at this point. I really want to make at least 185-190 ft-lbs. because that what will make the difference in the quarter. With the good rod ratio the power should be broad. The manifolds that I have intake and exhaust should be good enough to still make some top end with this engine size. We will hopefully soon find out.
Old May 12, 2008 | 06:08 AM
2fastGSR's Avatar
King of the One Liners
If you are looking to go big then why not do 86mm ?
295 is a big goal on a B series motor. I know some of the old pro guys were only a little over 300 with a bigger stroke motor.
I always liked shorter stroke motors , so i hope to see your goal attained. By the quality of your previous builds I'd say you have a damn good shot . .
Old May 12, 2008 | 06:30 AM
PURE Tuning's Avatar
Default Re: (BearsEK-KMSU)
Looking good, I will have some info on the head later today.
Old May 12, 2008 | 06:57 AM
EatSleepJDM's Avatar
looks good, kinda similar to my build except mine is 86X95, and shorter rods. hope you reach your goal of ten's, good luck im sure you'll get there.
Old May 12, 2008 | 07:35 AM
Shadowz7429's Avatar
woah, looks like an awesome build 2 weeks too
Old May 12, 2008 | 07:36 AM
h22crxpwr's Avatar
Default Re: Prodject 85x95 last attempt at a big B before building a big K. Kingmotorsports (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR &raquo;</TD></TR><TR><TD CLASS="quote">If you are looking to go big then why not do 86mm ?
I always liked shorter stroke motors , so i hope to see your goal attained. By the quality of your previous builds I'd say you have a damn good shot . . </TD></TR></TABLE>
87 bore ftw!!!
Old May 12, 2008 | 07:47 AM
Default Re: Prodject 85x95 last attempt at a big B before building a big K. Kingmotorsports (h22crxpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr &raquo;</TD></TR><TR><TD CLASS="quote">
87 bore ftw!!! </TD></TR></TABLE>
I wish
Old May 12, 2008 | 07:59 AM
emotionisdead's Avatar
Very Emergency!!
Torque-FTW!!! Should be a pretty stout setup to say the least.....
Old May 12, 2008 | 08:01 AM
Skunk2Tony's Avatar
Looks killer as usual Mike! Make sure to get some nic vids of the build and tuning.
....and then hurry up and run a 10 so you can join the dark side lol
Old May 12, 2008 | 08:02 AM
lohatch's Avatar
looks good mike. i've got an 86x95 deckplate engine i've been messing with.
Old May 12, 2008 | 08:58 AM
Default Re: Prodject 85x95 last attempt at a big B before building a big K. Kingmotorsports (Skunk2Tony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2Tony &raquo;</TD></TR><TR><TD CLASS="quote">Looks killer as usual Mike! Make sure to get some nic vids of the build and tuning.
....and then hurry up and run a 10 so you can join the dark side lol </TD></TR></TABLE>
The darkside is right but someone has to push the B still
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch &raquo;</TD></TR><TR><TD CLASS="quote">looks good mike. i've got an 86x95 deckplate engine i've been messing with. </TD></TR></TABLE>
How is it going for you??
Old May 12, 2008 | 10:29 AM
alterdcreations's Avatar
cryo valvetrain ..... hmmm
nice project.
in for results
Old May 12, 2008 | 01:19 PM
4g hatch's Avatar
Default Re: Prodject 85x95 last attempt at a big B before building a big K. Kingmotorsports (alterdcreatio
if you ran 11.30's witha 84.5x89 then you should be well into the 10's with this one even if you dont hit 300hp. what car was that in.
on the deck plate i see it has a gasket underneath. do you use longer rod bolts to torque it down, or is it welded. also will there be any cooling or headgasket issues with the slight gaps in the sleeves. i guess im thinking longevity and not a race motor
Old May 12, 2008 | 01:42 PM
Shawn C's Avatar
In The Garage
so sick, can't wait to see how this one turns out. good luck man
Old May 12, 2008 | 04:50 PM
1 2 NV's Avatar
Default Re: (Shawn C)
i was unaware that ERL still did the superdecks.
Old May 12, 2008 | 07:06 PM
jdm_ef9's Avatar
Default Re: (1 2 NV)
looks like a stout build...
interested to see the outcome!
Old May 12, 2008 | 10:34 PM
blacK_Dc4's Avatar
Default Re: (jdm_ef9)
love to see 300 whp and 10's ! good luck .. btw , have you decided which intake system you will use for this setup ?
Old May 13, 2008 | 07:44 AM
After a day and a half flow testing on the old head. Here is the before and after intake chart. This is the same head that received new seats. I would have liked to have seen 305 @ .500 but there was only so much I can do with the current port design.
Old May 13, 2008 | 08:00 AM
MikeySpec's Avatar
Default Re: Prodject 85x95 last attempt at a big B before building a big K. Kingmotorsports (PURE Tuning)
Good luck with the build! I cant wait to see it in action.
