ctr cams, 10.5cr pistons, 84mm LS block-----safe rpm?
Old May 11, 2008 | 08:01 PM
airmaxbri's Avatar
Default ctr cams, 10.5cr pistons, 84mm LS block-----safe rpm?
Hello,
Forced induction is in the future for this setup:
ctr cams with a street Port and Polish and aftermarket valvetrain, 10.5cr pistons, 84mm LS block (sleeved).
the forced induction part is still 2 years away.
QUESTION: will this setup make power until 9000rpm even with a 10.5cr? If so, what kind of power can I expect?
Should I go with skunk2 pro1 camshafts??
any input is appreciated
thx
brian
Old May 11, 2008 | 08:08 PM
unified112's Avatar
What is your bottom end looking like? ARP rod/main bolts? Shot-peened rods? A few more details about your setup would help.. But Im not totally sure about it revving to 9k. Though im sure a few more 'seasoned' vets might say differently.
Old May 12, 2008 | 05:16 PM
airmaxbri's Avatar
Default Re: (unified112)
fully built bottom end , eagle rods, wiseco pistons, arp heastuds and rod/mainbolts,
all expected mods of a built block
thx
brian
Old May 12, 2008 | 07:15 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: ctr cams, 10.5cr pistons, 84mm LS block-----safe rpm? (airmaxbri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airmaxbri &raquo;</TD></TR><TR><TD CLASS="quote">Hello,
Answer: It will make power til whatever rpm it chooses and the only way you'll know what that is or what to expect, is to take it to a dyno and have it tuned and then you'll know.
You could go with Skunk 2 pro 1 cams, but I hardly see the point. Stick with something like Skunk 2 stage 1 cams, Blox A cams, or even ITR/CTR cams which will all work well and still work well once you go boost.
Angel4768
Oct 1, 2010 05:04 PM
Civic*B16A3*Eg
Mar 1, 2007 02:46 PM
crxhybrid85
Nov 12, 2004 11:32 AM
sloweredcivic
Oct 2, 2004 11:25 PM
arw321
Jun 20, 2003 11:26 AM
