WHATS THE BEST SWAY BARS FOR AN EF CRX SI
Old May 11, 2008 | 05:00 PM
boostedflaredb16si's Avatar
Default WHATS THE BEST SWAY BARS FOR AN EF CRX SI
I HAVE A90 CRX SI WHR KSPORT SUS. .. I NEED A BIGGER SWAY BAR IN THE REAR CAUSE THE REAR KICKS OUT A BIT AT HIGH SPEEDS . IF ANY ON HAS ANY SUGGUESTION LET ME KNOW ALL INPUT IS HELP FULL
Old May 11, 2008 | 05:06 PM
dr_latino999's Avatar
Default FV-QR
A larger diameter swaybar will only increase the amount of "kicking out" you experience. I hope you mean high speed sanctioned track racing.
Old May 11, 2008 | 09:13 PM
neozero999's Avatar
Default Re: FV-QR (dr_latino999)
hmmm with ksport im guessing those are the coilovers with adjustable dampening... should check if the rear is too stiff, because if you add a stiffer sway bar it will just make it oversteer even more. kinda rule of thumb is if you want more oversteer *kicking out* stiff rear. but if you are experiencing snap oversteer maybe it be too soft in the rear or suspension components are binding * hard to move*. but if you would like a good sway bar i suggest the ST sway bar because its adjustable and is favored here on HT. goodluck !
88 EF Hatch
20
May 3, 2009 01:12 PM
exist12
Jul 15, 2008 10:57 PM
fireant
14
Apr 12, 2006 11:43 AM
ThefirstPACT
22
Feb 8, 2005 11:42 AM
