00-01 Spec R head code
Old May 11, 2008 | 03:49 PM
DA_JDM's Avatar
Default 00-01 Spec R head code
Do someone know if the code should be PR3-4 on the head???
No way to find the answer just by looking at the head...its a ported head with some aftermarket cams
Modified by DA_JDM at 5:04 PM 5/11/2008
Old May 11, 2008 | 04:26 PM
Fat Chick Magnet's Avatar
My 96 says pr3-4
Old May 11, 2008 | 06:31 PM
hayabusa160's Avatar
Default Re: (Fat Chick Magnet)
theres green paint by the dizzy on the head like behind it.
Old May 11, 2008 | 06:41 PM
Hybrid96EK's Avatar
Default Re: 00-01 Spec R head code (DA_JDM)
The R heads are the same casting as the B16 so they are marked PR3. They also have MILD work on the intake side stock. Nothing on the exhaust.
Old May 12, 2008 | 04:05 AM
DA_JDM's Avatar
Default Re: 00-01 Spec R head code (Hybrid96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK &raquo;</TD></TR><TR><TD CLASS="quote">The R heads are the same casting as the B16 so they are marked PR3. They also have MILD work on the intake side stock. Nothing on the exhaust.</TD></TR></TABLE>
the head is no longer stock ported...
Old May 12, 2008 | 09:21 AM
jdmboyef9's Avatar
There is no way to tell from the stamp. the best you can do is verify the year of the casting but all of the ITR/CTR/B16A heads had the same casting stamps.
Don't believe anyone that tries to say that all PR3-4 or PR3-2 heads are ITR. I have seen a few PR3-3 and my old CTR head was a PR3-1....
As far as the green paint behind the distributor, some of the B16A's if not all of them came with that at one time...plus the paint washes off easily.
If the head was stock (which it's not) the only way to tell would be to look at the porting on both intake and exhaust ports along with the tapered valves and valvesprings.
Old May 12, 2008 | 11:39 AM
DA_JDM's Avatar
Default Re: 00-01 Spec R head code (jdmboyef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboyef9 &raquo;</TD></TR><TR><TD CLASS="quote">There is no way to tell from the stamp. the best you can do is verify the year of the casting but all of the ITR/CTR/B16A heads had the same casting stamps.
If the head was stock (which it's not) the only way to tell would be to look at the porting on both intake and exhaust ports along with the tapered valves and valvesprings.</TD></TR></TABLE>
thanks
anyway with my port job it doesnt matter if its a ITR or SIR head...its gonna give the same result at the end correct??? if both head have the same headjob with the same cams???
Old May 12, 2008 | 11:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">
thanks
anyway with my port job it doesnt matter if its a ITR or SIR head...its gonna give the same result at the end correct??? if both head have the same headjob with the same cams???</TD></TR></TABLE>
It might even be better then stock ITR/CTR port.
Old May 13, 2008 | 04:45 AM
DA_JDM's Avatar
Default Re: 00-01 Spec R head code (Fat Chick Magnet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet &raquo;</TD></TR><TR><TD CLASS="quote">
It might even be better then stock ITR/CTR port.</TD></TR></TABLE>
hahaha for sure...i have a stage 3 porting My question was to know if the same porting would produce the same flow on an ITR and SIR head???
Jedi Jake
Apr 20, 2007 04:08 AM
Baodalazi
Nov 29, 2006 12:40 AM
turbo Si
Dec 15, 2005 02:17 PM
UJLSMoFo
Dec 30, 2004 06:38 PM
speedworkzb18
Nov 11, 2004 11:19 PM
