Transmission problem?
Old May 11, 2008 | 02:10 PM
gwegcivic's Avatar
Default Transmission problem?
hey guys, so i wake up this morning and go to get some mcgreasers. and as i am pulling out of my parking spot there is a pop and vola my car no longer wants to move
The car goes into gear fine. But it doesnt require the use of the clutch. Car will not move an inch without pushing it. there arel weird noises once the car in gear. \it doesnt stall out or anything.
It is sunday afternoon and there are no places open to even look at it today. It is my dd. Hoping it is something simple. But any ideas to what it may be?
Not taht is probably matters overly but it is a stock d15b in an eg. it has also been converted to a manual tranny, but that was over a year ago and never any problems there.
Old May 11, 2008 | 02:22 PM
team_exceed's Avatar
Default Re: Transmission problem? (gwegcivic)
well, if you did blow the tranny, the shifter would be able to spin in a circle around the gears. Try that and report back. otherwise, someone else may have easier help for ya.
Old May 11, 2008 | 02:51 PM
slowcivic2k's Avatar
Um, no it wouldnt......
Anyways...
Check your driveshafts first. If you snapped one, or it decided to break, the car will not move. Check to see if you have an axle turning when its in gear, that will pinpoint the bad shaft.
Describe a "pop." Do you mean a BOOM! as is common with an exploded differential? You gotta be more precise than "pop".
Old May 11, 2008 | 05:02 PM
geebs's Avatar
Default Re: (slowcivic2k)
put it in gear and hit the gas.. does the speedo go up? if it does.. its an axle problem.. if not its probably the clutch..
Old May 11, 2008 | 08:25 PM
gwegcivic's Avatar
Default Re: (geebs)
hey thanks for the quick responses. i have done everything you suggested. I can spin the shifter all over the place in gear.. but i have always been able to.. no difference there. got to get new bushings.
i did look to see the drive shaft but it is dark and rainy here so unable to see.. i will double check in the morning.
The speedo does move when started up and in gear. So is it possible axle problem then? Last time i blew an axle it was dragging on the ground? Dont haven anything like that this time. There is no oil or anything where it was parked and running.
Also the cluch showed very little sign of wear on it. Still grabbed very well up until today.
The pop sounded like a little ballon was poped. Nothing overly loud.
Any more ideas would be great. I was starting to worry bout the clutch and cost involved. I would have done it my self if it is the case, but lack of area of to work, and time it just wont be able to happen.
Old May 11, 2008 | 09:32 PM
danomatic93's Avatar
Sounds like one of your CV axles broke. Since I'm assuming you have a stock differential (not an LSD) the car won't move if and axle is broken.
Old May 11, 2008 | 09:37 PM
gwegcivic's Avatar
Default Re: (danomatic93)
i was wondering if it was a cv axle, wouldnt it still require you to push the clutch to get the car in gear? and would it not stall when you release the clutch. Sorry for the newb questions. Not overly familar with any type of transmission/clutch/axle problems.
Mhollaek9
Aug 17, 2007 04:58 AM
ek_b16
Dec 10, 2006 10:19 PM
Civic138
11
Apr 8, 2005 12:23 PM
BlueIntegraBoy
Jul 25, 2004 11:57 AM
