dizzy wiring
look i did a swap in my crx i first did a b16a2 out of a 2000 si then i sold the motor and went ls turbo but the ls motor is a obdo motor i got my car wired to obd1 and on the b16 the dizzy was obd2 so i wired the obdo dizzy back in the crx so i am trying to put the obd2 dizzy back in the car becaues i got my b16 back and i dont no the wires to put the bd2 dizzy plug back on can some one help me out
first of all, you need to use punctuation. i had to read you post three times to get what you were trying to say.
also, need to know what dist you are running. i can post the wiring diagram for any acura. but i gotta know for what car.
Ok bro sorry about that. But i'm on my phone and don't know how the use it yet man look the dizzy is out of a 99 ls teg. I know it don't fit on a b16. But i just need the wiring for a obd2 dizzy that's all bro . So i can stop driving my dad's truck gas in the thing is a bitch man and if you can tell me what wire gose where that would be cool thanks man
Well...I've tried doin that...i have a 90 dx with 99 b16 and i tried running a obd2 dizzy, but i remeber reading somewhere that it wasnt compatiable...even after that i found the wire diagram...(sorry, i lost it), so i went with obd1 dizzy instead and it works...but if you get yours running/working, let me know...cuz i would rather use a obd2, because i have more of those around.
OBD2 and OBD1 disitrbutors are identical just obd2 uses one plug instead of 2..
But I need a similar diagram.. I just did a mpfi conversion using the stock harness.. now i have to wire a obd1 plug onto the harness and the wires dont match up... I've searched on here and on other forums and they are all different and never correct...can anyone help me out?
all the colors should match up as far as the sensors go. (the colors are usually a bit faded, FYI) i just converted my EF to OBD1 yesterday and all the colors lined up on the OBD1 dist except the signal wire.
for a 99 ls
orange/blue - white/blue is TDC sensor
light blue (or blue/green) - blue/yellow is CKP
orange - white is the CYP
the signal wire is Yellow/green
Power is Black/yellow
and tach output is blue
good luck, if you need me to email you the actual acura ETM i can.
for a 99 ls
nycpatron
Jul 9, 2010 04:43 PM
crxfreak1117
Apr 22, 2007 02:55 PM
