idling issues, help!
Old May 11, 2008 | 11:50 AM
Serdar's Avatar
Default idling issues, help!
my car is a 91 crx hf, i have a y7 block and z6 head and intake manifold, p28 ecu. the symptons is the car revs from 1k rpms to 1.5k rpms and sometimes it gets lower like 600rpms to 900rpms and when i start out it hesitates a little then drive normal. there is a slight miss or loss of power around 3-4k rpm sometimes. engine check light is on after i reset it and is throwing #3. MAP sensor?
Old May 11, 2008 | 02:00 PM
EF'n C5's Avatar
Default Re: idling issues, help! (Serdar)
i'm trying to post the entire diagnosis procedure for code #3 (map sensor failure), its in pdf format, but I don't know how too.
basically of the three wire going to the sensor, one sould have 5 volts, one should be grounded, and the other is the signal wire. that one is the variable, at operating temp at idle, it should be around .8v to 1.0v. any higher than 1.0v is an indication of a vacuum leak, or burnt valves or incorrect valve lash.
but I would probably start off by just trying another sensor if you can find one.
let us know what you find.
Old May 12, 2008 | 06:03 PM
Serdar's Avatar
Default Re: idling issues, help! (EF'n C5)
anyone else have this problem?
Old May 12, 2008 | 08:06 PM
grog's Avatar
look in the faqs next time, theres a link for CEL codes and idling issues
FAQ https://honda-tech.com/zerothread/1508680
CEL codes https://honda-tech.com/zerothread?id=468260&page=3
It sounds like your problem is the FITV or IACV, but make sure its not a vacuum leak.
Idling problems https://honda-tech.com/zerothread?id=2153910
rtnlsltn
Jul 18, 2007 02:08 PM
ximportman
23
Apr 28, 2007 03:21 PM
91jdmcrx
Nov 17, 2006 05:01 PM
del sol1658
13
Sep 20, 2006 03:15 PM
the.hamburglar
Sep 2, 2006 02:36 PM
