2001 honda prelude
Old May 10, 2008 | 11:01 PM
immajackuup's Avatar
Default 2001 honda prelude
we started da engine at da starter and it started. but when we tried 2 strt da engine w/da key, it would not start. dash lights came on though. what would be da problem? had accidental frontal collision. pretty bad to da point where air bags were deployed. someone checked and said there wuz a wire dat is touching da ground or could be a wire dat is pinched, problem from accident. or could b somewhere 2 da relay box, i guess. please help. wat do u think it could b?
Old May 10, 2008 | 11:31 PM
dagle's Avatar
Default Re: 2001 honda prelude (immajackuup)
battery good?
ooh rip on me nm it started b4
is the ECU original?
Old May 11, 2008 | 12:09 AM
Default Re: 2001 honda prelude (dagle)
everything is stock
Old May 12, 2008 | 08:40 AM
lalallalalalalaaaa
Old May 13, 2008 | 06:06 PM
gstrudler's Avatar
Could be the immobilizer unit was damaged. And your post would be a lot easier to read if actually used "the" instead of "da".
Old May 13, 2008 | 06:12 PM
h23on17s's Avatar
3 main components in the starting circuit that can go bad... apparently ur starters fine... if its not ur ignition switch, its the clutch pedal position sensor, which obviously is on the top of the clutch pedal... but anyway, did u check all ur fuses? start with the easy stuff
Old May 14, 2008 | 01:17 AM
Silver Surfer's Avatar
Default Re: (h23on17s)
took me forever to read that and then i had to go back try to remember what i had read
^but yeah i was going to say something about the clutch sensor.......you did push the clutch in right?
Grumpy pigeon
Honda Civic (2001 - 2005)
Apr 24, 2017 07:44 AM
S13SR20
Mar 13, 2014 06:32 PM
blade_frost
Honda CR-V & Element
Apr 6, 2012 04:07 PM
Racars
Jun 15, 2010 09:56 AM
vikki4567
Feb 21, 2010 06:23 PM
