Searched - GSR odometer not working
Old May 10, 2008 | 10:45 PM
Turbo Dan's Avatar
Default Searched - GSR odometer not working
ok, so if anyone has been tracking my threads, i couldnt get my speedo to work, and after carefully looking up, wiring and replacing the electronic vss with another unit, i finally got the speedometer to work.
but here is the odd thing, the odometer doesnt work, nor does the trip meter.
but the speedo works perfect.
what the heck!
88 crx
97 gsr cluster
Old May 11, 2008 | 10:40 AM
grog's Avatar
Default Re: Searched - GSR odometer not working (Turbo Dan)
damn that sucks, I dont know exactly how this cluster works but I assume the odometer gets a signal from the speedo.
Have you tested the connections running to the odometer? I would guess it probably gets the same signal/volts that the speedo does.
Old May 11, 2008 | 10:54 AM
Hercules's Avatar
Default Re: Searched - GSR odometer not working (grog)
Try plugging in a different teg cluster and see if it works then...could be your cluster just being bad.
Old May 11, 2008 | 02:17 PM
Crx Jimmy's Avatar
most likely the person you got the cluster from rolled it back and broke it
Old May 11, 2008 | 02:26 PM
xsirenax's Avatar
i know this might sound a bit ghetto
but sometimes when i start my car the rpm shows at 0 and wont increase at all as i drive...so sometimes i gotta tap it a bit on the side of my dashboard and then it will start working
:D
iono if thats sorta whats up with yours but it doesnt hurt to try
DatOneGuy
20
Jan 25, 2015 10:45 AM
siregcivic
Oct 10, 2011 10:43 AM
civiccpedx
May 18, 2007 06:56 PM
EK SQUAD 425
May 10, 2006 03:28 AM
n1neb4ll
Jan 25, 2004 01:05 PM
